Hks Afr
jim260184
Seremban
http://i52.photobucket.com/albums/g40/jim260184/DSC00584.jpg
http://i52.photobucket.com/albums/g40/jim260184/DSC00583.jpg
http://i52.photobucket.com/albums/g40/jim260184/DSC00582.jpg
HKS Air / Fuel Regulator
The HKS AFR (Air Fuel Ratio Regulator) is a simple fuel adjusting device that adjusts the air / fuel ratio by changing the airflow voltage output to the factory computer. The AFR was designed for vehicles that are lightly tuned (air cleaner, exhaust system, header, etc), and that only need slight fuel-adjustment. The 10 setting adjustment indicator allows the user to richen or lean the stock setting by approximately 1.0 A/R point in either direction (richer or leaner). Each notch on the adjustment indicator will adjust the A/R by approximately 0.20 of an A/R point. Both the lean side and the rich side have 5 adjustments.
WARNING: Due to the nature of this product, a lean air/fuel ratio may be achieved and may cause detonation or serious engine damage. Because this unit is a sophisticated electrical device and can easily be damaged by improper installation, these units are sold "AS-IS", and are non-returnable for ANY reason. We strongly suggest that this unit be installed by a qualified professional who is familiar with this product.
http://www.hksusa.com/categories/?id=1920
Selling RM190 nego nego nego...
Location KL, Cheras, Serdang n setapak area..
Pls call 012-6622533 jimmy for best price.. Thanx..
hey man, your afr is of type D or type L?
can use for n/a car huh???im frm penang...u can send to here....thx
ok bro....wat the best price u can give.....i hope the part are in working condition.....hw u send the parts n hw i send the money...let me know....thx
Check the code behind or any engrave part number there, should be able to find out is Type D or Type L, for map using and afm using is totally different.
Totally agreed. Couldnt find those numbers on mine thou. Have an AFR tapped to my Putra's ECU now but it couldn't work since the AFR taken from a H22 Vtec. Suppose they have different sensor type.
