- Joined
- Apr 18, 2006
- Messages
- 3,677
- Points
- 1,663
can, why not? the engine won't be as powerful, but if you mean to start and move normally.. can.
ya cik budin...mine the simota type racecraft thingy...tot about using kadboard for measurement long time ago but till now not yet start measuring....lazy bum.......mayb can tiru this design kot...
walllaaa....inchey Udeng..u gime an idea oledi...gonna tiru dis after dis...
but to make properly hole..damn hard man..(on the slut section)...
so, post the picture once you'd done :D
what is the radiator hose material? where can i get it?
btw, how much does it cost to bore a 60mm to 64mm TB? Is any workshop in sunway doing it?
Usually how do we determine what diameter of TB to use? Any reference?
ichey udeng..i got one plastic sheild last time. i think it was from technical drawing bag(from vocational skool). From that plastic I tranform to aloi shield. kennot remember where I put oredi.
look around last 3 day..kennot find it.
Que - why even with air ram(from bumper diref facing to filter), feel like the CAI still not enought breath?
gooooo for 64mm evoX2. demmmm slurrpppp..make sure u had AFR to tune.any advice on the TB size part?
max size for b16a/b16b/b18cr TB (butterfly size) is 64.5mm.
u can have this size without any problem on idling.
this also will be good for ur further upgrade. no need to rebore it few times.
i can help u to send the TB to machine shop. the quality so far very good.
if i do the heat shield, i wud like to use something that is non-metal...so as to minimize heat absorption....but no idea what yet....
