- Joined
- Dec 21, 2005
- Messages
- 2,588
- Points
- 1,638
Why u want to take care of the piston? Its all engine oil and coolant job...
if 6 piston ring rosak so u need to change 6 ring compare to 4 ring at 4g91.
power wise of cos 6a10 better than 4g91.
6a10 has a larger block sure it consume more engine oil than 4g91 not rite merr??
Really,tat mean 2.0 block need 6-10 ltr of engine oil laa...It depends on your CC or cubic centimeter of your engine....1.3 - 1.5 use only 3.5ltr - 4ltr of engine oil,1.6 - 2.0 need 4ltr-4.5ltr of engine oil bigger CC consume more engine oil...Correct me if i'm wrong....
Bro correction,6a10 only use 4ltr of engine oil only....
Wat u have to take of is the oil pump and the water pump....Oil pump are very hard to rosak...
Almost 2 1/2 years i'm using tis engine it never give me any "high maintenance" prob...
Labour charge if u wanna change engine oil,only take rm5-rm10 only....
Labour charge if u wanna change timing belt,oil seals,water pump and spark plug only rm80-rm150...
But it will take u a long time because want to wait untill engine cool down...
It depends how "kamcing" u wit the workshop owner....
If wanna compare 6a10 stock wit 4g91 stock....4g91 loss by 3 to4 cars....Stock!!
If wanna compare 6a10 stock wit 4g92 MIVEC stock....6a10 loss by a half of MIVEC car only,side by side....
I tried it already....
hey bro, pls wear spec larr.
we are comparing 4g91 with 6A12. 6a12 is 2,000cc that is found in perdana.
this 2000cc sure use more than 4l of oil and sure the power is poorer than mivec cozs it only pumps 145bhp.
6A10 got sohc and dohc. the dohc is as wat u explained.
....that part ur wrong bro.engine don't consume engine oil unless the engine
got problem.
hmm i smell gun powder...chill out dude just discuss ma ... by the way 2.0v6 still can dump in wira chassis meh???
i try before 4G91 Manual and 6A10(1.6 V6) pick up before...actually almost the same...6A10 win by a little bit saja...both in stock lahAbout the title.....
Actually what i mean is 6A10 (1.6 V6) Vs 4G91 la bro..
Some mistake here...
Relax........... come pekena Teh Tarik..![]()
Bro,hope u explain more...Does consume in Malay mean "menggunakan"? Bigger CC use more engine oil is it? Like example 3.5 engine use 5ltr - 6ltr of engine oil...Correct me if i'm wrong....:hmmmm:
....By the way i'm not mad,just to share my experience only....
yup i've seen ppl doing this before...it make the engine compartment in Wira super super tight...barely can breathe that type haha...
Is that the 1600cc V6 I am seeing in this blue wira/satria ?
Maybe not much diff...
Never tried before..
I guess the feels for sure got big difference tough.......
Wrongly placed my post , kindly refer to the link
