NGV Converted Cars Community
baby_jap_wawa
Hi.. Lets share some of our experiences and knowledge about converted petrol/disel cars to run on NGV here.. :)
Baby Jap: you've converted to NGV?
I've heard from a cousin of mine who drives taxi that once u've converted NGV... after awhile.. a very short while, the engine will start to have problems..and even having said that, the hoses leaks every now and then. The long que for the NGV fill up is really a killer. Recently, i took a cab and i confirmed this with the cab driver as well. Is this true (3rd opinion)?
thanks
problem with the engine most likely caused by installing the wrong NGV kit, there are 2 type available in the market, the cheaper - mixer type are meant for carburetor cars, but most local shops will install it on your fuel injection cars also, thats when the problem arise...
the more expensive conversion kit are designed for fuel injection cars, it will not cause you any problem.
as far as leaking problems, maybe it depends on the installer's work quality....
does it really worth the price to install NGV? i did enquired for the install into civic eg and it cost 3.5k...anyone has installed the NGV recently...will the mixture of gas and fuel damage the engine?
main problem is cooling....as running in gas is more dry, the temperature is higher...so if ur cooling sytem is clogged...u wil get overheated easily...
and recommended to use higher VI engine oil to prevents engine oil molecues break easily....as combustion chamber is high temp n dry, lubrication system is very important here to protect it. otherwise ur valves, valve seats are easily gone..... :)
btw, rm3.5k in civic eg is quite cheap,if ur eg is efi engine....
hmmms.. what can we do to improve the cooling system.. if perdana.. what engine oil velosity is recommended.. ? =)
cooling system if clogged then just flush it lo...bottle of coolant + additional fan if required
my fren perdana v6 wit sequential kit using 10w50 Q8 f1 :P
hmmms.. if perdana v6 mixer kit then also use 10w50.. ? any diff between mixer and sequential for perdana v6.. ? eg short term and long term effects..
just wondering how many people out there really installing sequential kit for their FI cars?? coz the workshop i know seems to install mixer kit on every car that comes to them telling them it's fine... but i've already seen problem surfacing on these cars
reliability - i was told NGV has been used for years in europe and south american continent and they do not face much problem, is that true??
I will install the ngv kit if government promise not to increase the price of gas in drastic increase otherwise its a futile effort to do so, becos the ngv tank cost takes at least 1 year to recover.
Then another issue is that what will happen to your car value when you decide to sell your car with ngv kits, will the used car dealer take your car at great discount becos common perception is that ngv kit after a few years will suffer leakage due of the worn out of the piping. Usually they will treat your car like those taxi. You see installing the ngv kits is expensive, what about return the car to the stock condition of the car, will it be costly few years down the road from now? or will it be worthwhile to convert back to stock when you decide to sell your car?
my dad got ngv in his van...1yr edi n no probs...rm10=200km..
covered back the cost edi
natural gas wont damage ur engine... in fact, it increases ur engine lifespan...
in a normal fuel combustion engine, minor fuel will leak thru the piston ring and mix with engine oil.... normal fossil fuel will wash away engine oil, hence, reducing lubricant in ur engine...
meanwhile, natural gas wont wash away engine oil in ur engine.... lubricant maintains in ur engine, hence increasing engine lifespan up to 50 percent...
main disadvantage of NGV is loss of engine power (approx 10 percent) due to low engine volumetric efficiency.... another problem is cooling system... ignition temperature will increase and reduces valve seal lifespan....
main advantage of NGV... high octane level.... approx 120 (110 for LPG).... higher octane fuel eliminates knocking and detonation, hence engine can run smoother and lifespan increases....
just curious....
  1. izzit true that when installing the ngv tank at the rear, u have to go for stiffer springs/absorber? since the tank are heavy et al
  2. Any small car owner (Kancil/Kelisa/Kenari/picanto etc) have successfully converted to ngv?
asking because i'm quite interested
just curious....
if ur current rear suspensions are not in good condition then u hv to change.....if still ok then normaly dun need, however. my fren's wira 1.5 was upgraded to waja spring coz he owes full loaded with stock/passengers....spring below rm200 only one set for tat
kancil n kenari the most to install ngv compare to kelisa n picanto.....based on my customer lists le.....:wavey:
thanks for the info... i see that u do ngv installation?
