i had used the search button b4 but cant find something i would love to know ... anyone here can highlight me the 'pro and cons' of the 2 types of tuning ... thanks
If given an option between road tune or dyno tune
I would opt for road tune even it might be cheaper than dyno tune
Road tune simulate real time road condition for ex. uphill or etc
But not for dyno tune
Dyno tune is stressful for chasis and AT gearbox as compared
dyno is to simulate the road driving , but depends how much of load is put on the dyno machine which will tell u the wear and tear
how would it make diffrence if the dyno loads are set just as how u drive on the road, still the AT gearbox will be damaged ? huh how ?
only in malaysia its done that way, cheaper on road, more expensive on dyno , but if u see the overseas market , on road tuning aint cheap :D
For example, if u setting up a new combinations of; new turbo system + new ECU system + new air intake system + higher profile cams, u CANT tune on road, you need all the intruments on hand, which is inside the workshop, then u tune on dyno.
If no major changes, just minor changes like exhaust piping or openpods airfilter, u may tune on road.
Dyno can never stimulate 100% of the real car, it doesnt know the actualy wieght and drag factor of the chassis, hence the calculations are merely guessing.
Tuning on road, gives the tuner understand what the driver really wants to drive the car, can fully fine-tune piggybacks or standalones ECU.
This is my experience and my own opinions, I learnt all these from all my old uncle tuner frends![]()
:cool:Dyno results can only tell 70% of your actual performance by d good engineer.
:cool:All world class engineers will extract the remaining potential power by road testing.
:cool:Simple reason to differential d 2 testing - There will b no G-force, CD of d frontal area, Wheels rolling load, friction losses & ect when static wheels dyno in uses. All these factors have great influen 2 real vehicle performances.
Someone knowlegable hath spoken
:burnout...
