- Joined
- Aug 14, 2008
- Messages
- 104
- Points
- 1,516
Just finish tuning again the Honda EG B16 and change the spark plug NGK V power,Injectors 450cc,Stock cam with adjustble cam pully and add 3deg timing we get the 153.9 torque 114Ft.
haiyo..one more fella claiming v6 turbo std engine can go that high hp?
summore juz bigger injector and e-manage.
e-manage is nothing to me compared to standalone.
yes...thats one we need for all claim like del before.....im not tembak or flaming you, proof it first. share the dyno graph here.
i dont agree.... because..... im using e manage ultimate![]()
injector 450cc from what injector?how to convert torque Ft to kg/m?Just finish tuning again the Honda EG B16 and change the spark plug NGK V power,Injectors 450cc,Stock cam with adjustble cam pully and add 3deg timing we get the 153.9 torque 114Ft.
im not sure... but hp figure 5% increase might be more aless the same... but at bigger horsepower... the 5% can simply mean from 20-40who.... where else for a car with 200whp... the 5% can be a merely 10whp only..
but you sure the v6tt can do 190whp on wheel? last time 1j stock standard go dyno (no up boost fully stock) only get 221whp only as opposed to the 280bhp on paper. not sure though... not playing with mitsu enough yet...![]()
:wavey:yup...think renxun, i know u playing with 1j, that is diff story.stock factory std oso power oredy.
ppl here claiming v6 twin turbo(2x small turbo than l2) stock engine can go 300bhp+e-manage and bigger injector???? stock v6tt only produce around 190hp stock std on dyno!
how many hp u can gain jus changing the value of air fuel? or perhaps ignition?
think!:hmmmm:
they claim around 260hp, but mine fren v6tt stock std just change the exhaust to 2.5inch only produce 190+-bhp.
imagine evo3 stock std only produce 230bhp on dyno and they clain 260hp!just put standalone only produce 255bhp! but the torque increase very well, i cant remember the figure.
renxun, your kips how many hp? ehehehhee!!!:wavey:
Guys, since we're on the dyno topic here, I've a noob question to ask:
In what gear is the dyno run taken; always 3rd gear in 5 speed gear boxes ?
I did mine in 3rd gear but I was told in a Mat Salleh forum, they do it in 4th gear coz at 4th gear, the gear ratio's closer to 1:1, hence making the result more accurate.
So who's right ?![]()
Guys, sifus, anybody ??:wavey:
Not necessarily, depends on how much power you're running and how short of a gear ratio you have. i normally do a power run with 4th because it takes longer and the wideband O2 can sample more per second for air fuel reading. Low powered vehicles or with slightly taller gear at 3rd can also do dyno pulls and high powered vehicles sometimes needs 5th gear.
Yes..u have to run the power with 4th gear.
Thanks for the answer, sifu. Now I understand. Then probably because my car's a NA Toyota:slug: , that's why it's done on 3rd gear.last time i have to do my dyno pull on 4th because on 3rd gear my tyre hop and spins on the dyno drum when the boost kicks in......and couldnt get any accurate reading from there... and as mentioned the sampling time for af ratio is too short as well...
im not sure about NA cars... but for my case... i retard my ex cam timing 5 degree for the slight increase in top end area
Stock standard : 163.94 ps / 17.37 Kg-M on wheel.
