what about bc288 or jun?
wah , i saw a nice cam, able to cope with 11krpm
http://store.forcedperformance.net/merchant2/merchant.mvc?Screen=PROD&Store_Code=FP&Product_Code=101FP5R&Category_Code=DSM-Engine
[SIZE=-1]DSM FP5R P/N 101FP5R
Spring upgrade required, must check for coil bind. 11K RPM capable with good springs. Further increase in upper RPM power. Intended for use with 65+ lb/min turbos. Works well with header equipped engines. While most aftermarket pistons allow for adequate piston to valve clearance, checking clearance is highly recommended, especially with oversize valves. Choppy idle, not recommended for factory ECU's or any ECU that you cannot disable O2 feedback at idle. Recommend increasing idle RPM to ~1200RPM.
I saw the cam card huhuhu , i dont tink jun or etc has tht high lift , FP5R got 12.065 mm lift :D
[/SIZE]
at the race event like sdb, jempol, terengganu that putra piloted by awek pakai tudung.
... the service that they...
