one more systoms i notice on this carb is that when i deccelerating, off throttle, i can hear the 'poping' sound from the ekzos paip...sounds like a lean poping to me...but i still not clear how to solve the hessitation....jerk everytime i press the gas padle really makes me to loss confident of driving this car...sifu pls help me to teach this naughty 4g91 carb...thanks...![]()
dis thread still alive..............fuyoooo...........![]()
hi, i'm having some prob wif toyota se 4af carb. (standard carb)
1. the car doesnt feel rite (b4 this felt really torquey n surprised wif d pwr even 4 stock engine )
2. got strong fuel smell from the muffler (change your fuel line rubber, change your fuel pump, change your petrol filter)
3. Carb leaking (check all the hose to your carb, from petrol to air)
4. spark plug black color (i think 2 rich gua) (yeah, very rich and advance timing)
Things that ad done
1. carb cleaned using wd40 (waste money and time, use ur hand to pump & tarik d throttle 9 9)
2. new air filter (no difference)
3. new spark plug (use back normal plugs, no.5 or no.6. dont go use high end 100 buck per stick kinda plugs)
4. new petrol filter (then it must be your fuel hose rubber located under/behind your trunk which is the fuel tank)
5. noting wrong wif spark plug cable (check your distributor and ignition coil)
6. did tuning ad (many times actually)
Went to a few diff mec (min 4 -5), all saying diff things. These are the probs listed by the mecs
1. Carb kong ad (hav 2 chnge cuz smthing to do wif butterfly not opening)
(this one big possibility)
2. engine compression out (need over haul)
(no such thing)
3. change 2 4age
(i also can say that, in fact say it to many ppl, many times)
4. old car ad ma, so normal laaa....
(mine older then yours, so how??)
im seriously tired wif all this.. can anyone suggest or enlighten me on wats d real prob.. is it the carb or the engine?
any replies will truly b appreciated...
3. Carb leaking
Things that ad done
2. new air filter
3. new spark plug
3. change 2 4age
3. Carb leaking
Things that ad done
2. new air filter
3. new spark plug
3. change 2 4age
carb era will be here always, we never forget our roots![]()
bro skywalker,
yes, u r rite.. leaking at the bottom... but the mec i go to says its not the gasket.. at first i tot gasket bocor, but he say carb hav 2change.. actually d mec use wd40 to clean d carb..
.. see ... what dumb ass people would do...
