i mean the Fuse....
waaa change fuse can burn car ah...scary![]()
if i change form 20 to 25A? ok?
noticed one more thing..when the car is accelerate, there won't be any problem of dimming...but while idling..very obvious : /
so huakenny, regards the grouding wire..how a?
Because more electricity is moving through your alternator. Do you know the alternator works?
Thats the same reason why if you forgot to turn off your headlights and you switch off your car. Your car most probably wouldnt start when u try.
bcos of ur alternator spin more then produce more current...
yo all bro out there i solved the problem 100per cent. Installed a michiba booster solved all . Yes! No dim
Here are some Evo X that i snap back from Super import nights... :-Chua :stupid::ciao:
