and that means...? jun better than bc?
with max lift , and degree, it doesnt determine the performance yet :D
so cant really say bro unless u got the full spec , ramp rate , etc everything of the cam spec
headache already.....jo1 suggest bc, joshua says jun top end graph naik...haha....
If money and waiting time is not the problem just order the fp4r or 5r... but for your turbo BC will do. If JUN is your choice, it the best cam for 1g and 2g aside from GSC and FP but the price is a bit high.
not abit high laa wey..it's way too high ehhehe..as for me..just go for bc280 or bc 288,worth the money..hks 272 also not as gud as bc272 if i'm not mistaken..
Bump: Hey we always talk about hks,jun,tomei,bc,fp how bout this poor little kelford cams? Any comments?was thinking of changing my bc272 to kelford 280
bump: Hey we always talk about hks,jun,tomei,bc,fp how bout this poor little kelford cams? Any comments?was thinking of changing my bc272 to kelford 280
u said fp4r/5r is overkill to my setup right? joshua likes BC or not? i'm afraid if he is not familiar with that cam,he wont be comfortable. if he is not comfortable,he wont push to the limit.
FP4/5R is good for your current spec and future upgrade.. it better you have it when you need it rather than don't have it when you need it. If you continue with the current spec bc will do, no need to source the fp which required waiting time and extra money.
Joshua is a good tuner.. cam selection will not limit his tuning skill unless you grind your own cam with a grinder.
buy both la...hahaha and try one by one...![]()
anyone have try highest rpm on 2.4?
hahaha... iheard one of mechanic at my place grind the cam itself....
satria fadil 3rd podium on class b final round sdb 2008
engine spec 2.4 , vg piston , oem mitsu conrod , 272 / 264 aussy cam rev can rpm 10k on autometer tachometer.
Bump:
my father also grind the camshaft itself bro. no problem , keta laju jgk. ha3![]()
Like i said,it's a drag car not daily driven car :) u can rev it pass 8K rpm but interm of reliability.how long can the engine last? :) cheers
but i am quite surprise most people whacking vg piston in most big turbos n further more this piston is 87mm already....this piston dont go into peaces when ur whacking on high boost or big turbines
Bump: but i am quite surprise most people whacking vg piston in most big turbos n further more this piston is 87mm already....this piston dont go into peaces when ur whacking on high boost or big turbines
