how if i maintain my 510CC injectors and add another 1pc extra 700cc injectors? is it sufficient enough for 400hp?
guys...just to get ya feedback....currently i am running 2.2l crank with 87mm pistons in a evo 2 engine with a ar.50 garret turbine
my question is ..shall i used 272, 280 or 288 cams and whats the best cams to use??
ditch the 510 injectors bro. Go get urself a decent minimum 750cc injector to get u to the 400hp mark.
basicly, i have to upgrade minimum to 750cc injectors......hmm ok...
thx for the advice guys
not just injectors bro,how bout ur turbo?piston?conrod?cooling system?monitoring devices?
standard ecu with chips n piggyback will be enough for ur setup for now.
standard bottom end wont bring u to the 400hp mark safely. Do some more readings bro. Hate to see people blowing their engine huhu..
true true goo_61t.....dam it really heart breaks when u c your engine into peaces....which happen to me last month while in a game...dam gone all the money got wings,
thats the reason i have to build from scratch now and decided to use 2.2l crank with vr4 rods and vg30 pistons with ACL bearings
what i am still thinking can these items withstand the pressure if i used a GT35r turbine
currently i am running AR.50 garret only
and my management also i am still using hks fcon-v
sard fuel pump and 750cc injectors
thats why still deciding what turbo and cams to use
gt35r depens on ur boost laa bro..if ur going for like 2bar pretty sure u'll hit the 500hp barrier,with vg30 piston,vr4 rods wont last long i guess..kadang2 high boost boley laa..but the piston and rods is what concern me. If ur still running ur old turbo i guess will be fine la..
alright goo_61t
well since its again gona cost me alot to forged all my internals again....then shall just stick to my ar.50
further more 87mm forged piston is gona cost alot
but i just love the way how gt35r spools and drives the madness power
ada bran bro...
sdf: u mean ur Galant VR4 ah?..cun bo 13cents/km for a 400hp car..even my stock gsr also doing 22cents/km..
Wrongly placed my post , kindly refer to the link
