- Joined
- Dec 8, 2004
- Messages
- 392
- Points
- 3,028
so what are the piston size ur suggesting?? 85.5mm or 86mm
gt42r can neva be in my budget...so expensive
bigger piston equal to higher weight and stress to bearing.... lighter piston don't stress on the bearing so much and achieved faster rev.. for me i'll be using 85mm if possible, if not use the next available size. Don't forget about the cylinder wall condition, check the smallest possible piston that can be fit with minimal honing work for fresh cylinder wall, at least you have a option for bigger piston if you need to do overhaul in the future.
When you use 87mm, that will be the largest bore 4g63 can accept and still maintain it reliability, for larger bore than 87mm you need to use 4g64 block.
