4g15 carb to fuel injection
Dear skywalker...
sure can use old dashboard wan... what im trying to say is wira injec. comes in 2 wiring.. 1 is for ur engine injection system and the other is for the tuning purpose... For injection model dashbord, there is few extra wirings compare to carbie model dashboard( The wiring for the engine check... This wiring is connected from the ecu to the wirings in the dashbord for tuning and light for the engine check...
If u want to stick to ur exsisting dashboard, is not a problem... u can either simply change ur speedometer or add 1 lamp in ur exsisting speedometer and pull 1 cable out straight to ur ecu.. try to find light green+red wire at ur ecu wiring ( there are onli 2 of those.. one is bit darker green)
And for the tuning.... well.. ive been scearhing all over the net and wiremans all around KL and none can do the wirings...have olso they say tak berani la boss.. and i need to get the socket for tuning too :banghead:
so dear skywalker.. it is just a prevention purpose onli... the tuning is only for checking the engine onli.. or u can always do standard try and error if the car gets F**ked up later... (if u dont have these cable...) unless u are a good mechanic..
if u dont know DONT REPLY and dont simply get other poeple to get cofused ok...
sorry in advance
bro,
u using vdo or mmc type of injection?
dun tell me u using the "tuning socket" for ur mmc type of injection..
and another thing..reply properly la..dun simply bash skywalker lor..wuts with the caps lock..
if u noe everything..explain slowly ler..as we all r plain stooopid izzit?..:smokin:
Not the same interm of wiring la... If can find a good wireman then can use ur old dashboard.. if u can get the socket and try to copy the wirings from other inj models wira.. Yes, if complete it should come wif the tuning socket.. i think better stick to carbie.. coz no significant difference in performance compare to 4G15 injection.. even FC oso not much diff. If wan to change to inj. better go for 4G91..(if looking for 1.5 lah..) quite old but very reliable mitsu engine... plus u get a nice dashboard wif digital aircond too.. :biggrin:
Btw, the dashboard at chop shop does not come wif the wiring.. only the kosong dashboard..
Just for info, if wan to install these wirings, it will cost u around 1.8k at Proton service center..Just for the wirings tau.. New complete original wiring..
so dashboard & wiring differ le between injection & carb..
so wiring socket also attach at dashboard ka boss not attach at engine wiring..
if i want to buy dashboard kosong from half cut how to see the diffent between injection & carb dashboard..
then if i buy carb dashboard kosong at halfcut then i'll be d**m le canot install at injection..
better u stick wit carb..
that of course if u r a racer..
carb save petrol on high speed..
but still lack on pick up..:rofl::burnout:
eh dint notice this....how come carb save petrol at high speed as compared to efi?
carb lack on pick up compared to efi?
wondering y u tell racers to stick to carb when u sed it lacks on pick up hehe
Dear skywalker...
sorry in advance
good info, but chill on the attitude boss
Cheers!
wat happened??... wiring dashboard ahh??... ooo... sorry la i noob mah.... i didnt know the wiring are built into the dashboard where u need to change the whole dashboard jz for the check engine light....
that y i want to ask this highlander guy..:listen:
sure or not wiring built into dashboard..:confused:
done my carb to injection without so much hassle..
if sifu sky noob than me is for sure super noob..
so, did u change the whole dashboard??... how much does it cost u in total??..
no change dashboard lor sifu sky..
change the wiring..
no need to rewire the check engine like so what ever..
meter also change to injection one..
cost i dont really remember..:confused:
done this carb to injection conversion years back before convert the whole engine..:slug:
but roughly injection conversion part cost about 500++ not include dashboard..:idea:
got injection part from wira SE complete with head from a friend..
installation not so much cos like doing it with my friend..
some wear & tear part & cigerette only 100++
but the knowledge doing it really worth it..
with all the facts laid out by the sifus, then i guess it is no go for iswara... :bawling:
btw happy cny for those celebrating
