- Joined
- Feb 10, 2007
- Messages
- 1,220
- Points
- 1,638
Dear skywalker...
sure can use old dashboard wan... what im trying to say is wira injec. comes in 2 wiring.. 1 is for ur engine injection system and the other is for the tuning purpose... For injection model dashbord, there is few extra wirings compare to carbie model dashboard( The wiring for the engine check... This wiring is connected from the ecu to the wirings in the dashbord for tuning and light for the engine check...
If u want to stick to ur exsisting dashboard, is not a problem... u can either simply change ur speedometer or add 1 lamp in ur exsisting speedometer and pull 1 cable out straight to ur ecu.. try to find light green+red wire at ur ecu wiring ( there are onli 2 of those.. one is bit darker green)
And for the tuning.... well.. ive been scearhing all over the net and wiremans all around KL and none can do the wirings...have olso they say tak berani la boss.. and i need to get the socket for tuning too
so dear skywalker.. it is just a prevention purpose onli... the tuning is only for checking the engine onli.. or u can always do standard try and error if the car gets F**ked up later... (if u dont have these cable...) unless u are a good mechanic..
if u dont know DONT REPLY and dont simply get other poeple to get cofused ok...
sorry in advance
bro,
u using vdo or mmc type of injection?
dun tell me u using the "tuning socket" for ur mmc type of injection..
and another thing..reply properly la..dun simply bash skywalker lor..wuts with the caps lock..
if u noe everything..explain slowly ler..as we all r plain stooopid izzit?..
