shit...y my car cant boost on the 1st gear
muikit88
Malaysia
folo the title...
my car cant boost at 1st gear..
i tarik until 6000rpm the boost oso not boost at all...
oni 2nd gear n 3rd gear oni will boost~
sumore my boost maximum oni can reach 0.45...is tis all normal ?
Bump: not ppl can help me meh~ or it juz locked by power fc ?
Uhm... I can give you this link but I am not sure if you would find it useful coz its unlikely you would have the tools or inclination to check
http://www.rx7club.com/showthread.php?t=802060&highlight=turbo+control+solenoid
Its likely your solenoids or valves stuck up, take it to any mech who does turbos and have them checked. If you are running stock, do be careful coz twin-turbo setup. Most mechs are more familiar with single setups.
now u r using power fc?
this problum maybe is some of the solonoid valve rosak
,bcos last time my car 2nd turbo tak ada, i meqns when i got 2800 rpm 1st turbo come, then after 5000rpm like NA car no turbo boost at all
then i send to check ,found that 1 of the solonoid valve is rosak.
now 1st gear rpm 2800rpm 1st turbo come, then 5500 2nd turbo come togeter.very good power.
all above is original ecu and original engine
hmm, you need to provide all the necessary infos regarding your problem. just stating u didn't get boost in 1st gear until 6 tou isn't enough even for a pro shop to detect your problem. The worst case if the mech to malas to diagnose , they will tell you to replace all solenoids or even entire seq turbos. :shot:
"my car cant boost at 1st gear..
i tarik until 6000rpm the boost oso not boost at all..."
maybe your boost gauge faulty?
boost stays at 0? or stay in vacuum area? or above 0 but not much?
do you have boost controller that can tune boost relative to gearing like avcr?
maybe someone messup with the pfc before?
"sumore my boost maximum oni can reach 0.45...is tis all normal ?"
normal healthy stock working seq twins would give 10-8-10 psi or 0.7-0.56-0.7 kg/cm2 boost pattern for 265hp model and for 280hp will give 12-10-12 psi pattern i believe.
So 0.45 max is way too low and definitely your car have some leak somewhere. This is very time consuming to diagnose but it can be done if you have a strong will and a lot of patient. ic coupler/vacuum chamber/the shitty solenoids with their vacuum hoses all can be a culprit.
as someone stated above maybe 1 or 2 or even 3 of your shitty busukbesi(mitsubishi) solenoids had failed under the hot upper intake manifold + hot and sexy malaysian weather. A SIMPLE CHECK to this shittynoids would require you to open up the uim and check the noids resistance with multimeter OR a click sound when tapping it to a 12volt source while the car is still hot and sexy. Doing it while the noids still cold might be useless because the noids might act normal when the temperature is not so torchering. Ahh, how wonderful is that? It is very interesting job to do, believe me.:thefinger:
If you have a year 99+ shittybox solenoids system things would be easier just a bit when checking the shittynoids. but make sure you know what you're doing!
My advise, if you really really love your car and want it to be in good condition and save a lot of money you better start learning about your car and help yourself. The internet is full of informations (good ones and also very bad ones), just be patient and absorb all the good ones if you're really passionate about this car. you are still young and you have a lot lot lot of time to learn!. :wavey:
"open up the uim and check the noids resistance with multimeter OR a click sound when tapping it to a 12volt source while the car is still hot and sexy. Doing it while the noids still cold might be useless because the noids might act normal when the temperature is not so torchering. Ahh, how wonderful is that? It is very interesting job to do, believe me."
mm... i may have to research more or ask somebody for this... still noob.
thanx for your info!:adore::adore::adore:
last time i spend only rm100 for this problum .they check about 2 weekto get only 1 valve rosak.check it 1 by1
Muikit: I've read TK's blog. Please take your FD to Ah Choy in Subang. Have a day trip.
Do change all the solenoids and vacuum hoses. Also have the wastegate looked at and consider up-rating your radiator to a koyo double-pass unit - ah choy can source for you.
And get your brake pads changed - especially if you are looking to have 0.8 or more bar of boost, dont want you to crash that FD.
haha..savahn...seem i wan go crash my car ?>.!
i think i will arrange 1 day free n sent my car to tk fren...
tk got very nice skill, sumore he is a ex rotary player~
check yr AFM or ...... MAP sensor if u're using Power FC
Sometimes we do not want to crash but crap can happen. If you up bar to 0.8, zero-to-hundred times drop a lot. This decreases your margin for error. If you dont have sufficient stopping power to deal with mistakes... oops.
TK's quite good but you'd expect that for an advanced driving instructor. I wanted to go for his recent class but it was on a Friday... and I work regular hours.
yup savahn...he reli a nice ppl...
but he very busy 1~
not reli dare to kacau him everytime~
How bz can he be when he's driving every morning and every night?
