still using it until now. dunno exact model...got at chop shop, they said its from camry 2.2 yr 96, the socket is same... 1st week use the cable burn, fix it then kautim.
t-la, you tha man la!! thanks bro! everything is working fine..all lights are brighter, idling better, a/c more powerful, etc...
bought it during the weekend and installed it. it's from a 5S-FE 2.2 engine.. it's a direct fit and I learnt that it's a bitch to take out an alternator from a AE101 20v! They should have just put it on top of the compressor like the 4afe and the 5S engines!!! hehe..
anyway, no mod done but the socket was different..it's just a matter of joining the old wires to the new socket..very straight forward coz the colour of the wires are the same. See pics la..
The one with the blue tab is from the 4age svt (70amp)..green tab from the 5S (80apm)
i think you meant alternator and not generator rite? all newer alternators comes with a regulator.. it sits below the heat sink area...the belang2 part which looks like ur pc's processor heat sink. it allows constant power to charge the battery..the bigger the amp the bigger the battery..so easily put, if you're using an alternator from a 5S engine, just make sure that you're using the same type battery that comes stock with the car..
whatever you add in the car, be it better alarm, ICE, spot lights, this and that meters, all take more power which your stock battery/alternator sometimes can't cope..
anyway, i went to a battery shop to check if the voltage is good (use proper meter from the battery shop and not the ones that sell of the shelf volt meters) and before i changed it, daytime driving, it reads ard 12v. nighttime, 10.5/11v. after i changed it, NEVER below 12.5 at any given time..
Sorry bro, I can't help you there as i've not tried it.
but what's important is having the same fit alternator..that you'd have to try or maybe you can measure it before going to the chop shop.. your's should be easy to measure as it sits in front of the engine..
I'm planning to be a proud owner of a MR2. but before that i would like to know if the mantainance of the car very expensive?? are spare parts hard to come by?? how bout fuel comsumption?? and what other issues it...
