ok here it really show you are still new in this forced induction thingy, since you want to get into details , let me shoot you some info :) dont get angry, information sharing n you are welcome to reply n discuss
your statement clearly stated "you want the flutter sound"
ok thats your main aim
secondly yes, it can only be achieved by causing compressor surge
when you mentioned about PBV , ehem, if u have a PBV u wouldnt have surges too,
PBV is BOV which is recirculated , PBV has aftermarket as well as , a stiff PBV will cause surges as well
these are the few bov's that can be a BOV or a PBV
greddy type-r
greddy type-s
hks ssqv + recirculation kit
blitz ss
GFB certain models
turbosmart certain models
synapse
the list goes on :)
this is how a HKS recirculation kit looks like , so it will make the ssqv a PBV
http://www.gpiperformance.com/images/HKS-Recirculation-Kit.jpg
a stock car doesnt need a aftermarket BOV unless its 20psi n above, tht is totally wrong , an example an evo , from experience n fact , an evo 1,2,3 PBV will leak aprox 14psi , the later evos have much stiffer spring setup , the evo 8 MR has a steel body to replace its plastic PBV's , the old school vr4's has much stiffer PBV compared to evo1,2,3
evo 8 stock plastic PBV
stock evo9 PBV
so it really depends on the car n engine model to know wht PBV it has and how much it can hold , but ALL PBV will be able to hold stock boost with no probs, anything greater would depend on its model n make
so here comes the topic again , the aim you have here is COMPRESSOR SURGE which causes the flutter, so in other means, regardless its PBV or BOV , it will effect performance and lifespan of the turbo.
here is a DIY airticle by the gurus on how a stock 1G Eclipse PBV was crushed to make it achieve hold more than 13psi
1G BOV 101 / Mods - DSM Forums
so the topic here is i really want to know is it
"BOV NOT NEEDED" or is it "I WANT COMPRESSOR SURGE SOUND"
because from your first post , the intention is to have compressor surge sound regardless of BOV or PBV :)
if you are meaning car doesnt need BOV because it already has a PBV, then err i guess the topic ends here, cos all of us over here know that for a fact , every petrol turbo car will have a PBV as stock and it can be replaced with a aftermarket PBV or BOV if needed. Err im still confused, so wht does it got to do with the Flutter sound, err thank you. *confused*
to know more, why a stock car is not fitted with a BOV instead of PBV, it relates to Airflow sensor vs Map sensor fitted cars , enviromental issues and etc :) , i guess tht has been discussed in the other threads already.
just adding another thing, errr u mean tuner as in EMS tuner ? wht does a tuner got to do with the compressor surge at all , *blur* , a tuner ensures the car runs at a correct AFR at correct boost n rpm , wht does that compressor surge got to do here bro, so meaning if im having compressor surge, a tuner can tune my car till it goes off ?
and i dont get the meaning of "with bov easier to tune"
peace
flutter sound topic or pbv/bov ?
thank you
