Bump....For newbies...
Was reviewing threads that i started....
Many good dicussion here for engine /block selection...
So bump...
Totally good topic and loads of info 2..
Really apreciated it guys...
So bump...
Which setup is more reliable for daily drive and high rev(9000rpm)?
1. B16b + B18cr crank but use back b16b rod and piston
2. B16b + B18cr crank + b18cr rod and piston
3. B16B head + Use back my B16a Block and stroke to 1.8cc? ( Any suggestion how to build this setup?)
Small budget set ups...answers
1. kenot...piston come out of block. If change special ordered piston can.
2. Can... better is 18 crank, 18 rods & 16b piston.. higher CR= higher hp
3. special piston needed... crank 18, c/rod 16A..
For setup 3, Can use b16b piston mod with b16a rod?
E-tech: thanks for sharing alot of useful information. Im still new in vtec mod.
Normally if we change to b18cr engine from 1.6cc need to go puspakom do inspection or just go jpj to register? My fren change to b16b no need go inspection just go jpj but not sure bout B18c.
For my case...
B16A--> B16B went for puspakom...reason different "A" and "B"
if a B16A to B16A no need puspakom.....
so
B16A-->B18C sure must puspakon cause cc up...
But sometime different location different law.... u know lah...
MAS... mana ada system..![]()
Bro...
Basically cannot.
B16A block is short... when put in 18 crank & 16a rod n 16a piston, piston will come out of the block already.... like alot of mm... same if use b16b piston, even more come out...
Spoon sell this "stroker kit" for B16A block which is basically = B18c crank, 16A rods and special short piston wit just 1 oil ring and 1 compression ring...
If budget constrain and onli want to pay 1.6liter road tax...
just get b16b block + ur B16A head first...- better high rev gain
When got $$$- next CTR type r cams
When again got $$$$- get a 18c crank & rods
If dun mind 1.8liter road tax....
just get a b18c block + ur 16A head..
If want to "cheat" and take risk...(block punch number "B16A")
B20 block + B16A..
For me it was B16B block + B18c crank n rod + b16B pistons...
all up to u.![]()
hi i noob here i jz buy a so4 engine set up like this head b16ainside ctr cam n valve spring,skunk2 manifold,s90 tb,cam adj cam pulley,b18c gsr block,b18cr piston n hondata s300 ecu.can this block put in B18cr crank n rod?can it give power?1 more thing when i hit rpm5000 vtec open but power drop till rpm6000 power only come dun know wat problem.any sifu know wat problem wit this set up?all pls help thnaks give some advise pls.
