Wow...that's a lot of info to digest...good thing I haven't go & waste my money trying bit by bit. Thanks guys. Maybe I'll just transplant a gze and turbo it instead of going thru all those trouble. By the way, do u guys think I should go ahead & change the original 4afe gearbox to 4age ST gearbox?..since I've bought the gearbox...
---------- Post added at 09:28 PM ---------- 6 hour anti-bump limit - Previous post was at 08:58 PM ----------
How do u guys learn so much on these performance parts? Is there a 'school' where I can learn all the skills?:stupido: I never get the chance to experience it since ppl here just do transplant...not good at troubleshooting. Guess im more on the curious side. Only lately, since I've read forums that most 4a parts are interchangeable, that I change those original pistons to bluetop. First 'experiment' done, now comes the gearbox...I wonder what's next??
lucky you not go ahead... ST and BT gearbox are the same with 4AFE... You may put it in and feel the engine much lighter, but after you done you will relief something different in speedo rpm there. I rev higher, but achieve speed lesser.
Anyway I study in engine engineering... and because of love in modification world and always do the research too. Then development.
---------- Post added at 12:39 PM ---------- 6 hour anti-bump limit - Previous post was at 12:34 PM ----------
no la... what im trying to say is to build a TC kit from scratch is not cheap. Buying used is cheaper. But then, its different "taste" of everyone.
3S is power no doubt but need to rojak alot of thing to be in order to drop in seg, gb, driveshaft, and so on. not to mentioned mod mounting is required which is something i dun really like. If u analyse deeper, the more thing u rojak, the more headache u got. If 1 day, u dun like this mech and decided to go for other workshop, or ur car brokedown somewhere far frm ur workshop, i doubt u can simply drop into 1 workshop and the mech knowing wat rojak parts you're having.
As for 4AGZE, best bang for the bucks. Halfcut cheap, around rm4500 region. But driveshaft is hard to find not to mentioned its very ex to source. Moreover its almost cant be upgrade in the sense tat you can only change to smaller pulley to up boost. Even that, thr is a limit. stock gze boost .5bar if im not wrong and max u can go is .7bar. Anything more than that, you're cooking the compressor changer. Alternatively u can change to SC14 which is frm Estima but hard to source and its not plug and play. Despite all these, 1 thing i cant bear with GZE is the FC. Damn it drinks fuel like no tmr. I've borrow my ex mech GZE seg for 1 months, i surrender. So what normally plp do with gze? turbocharge it. Again, u will need to spend all those i listed before, turbo, manifold, and so on. The only thing u save is injector, fuel pump and map sensor. The rest of item, u will still need it.
So u sump it, GZE halfcut rm5k, install labour + tear wear cost + RM1.5k. Total 6.5K then u add turbokit on it, another 5k, so total u spend? whopping 11K
for 3S, for save work... you may brought the SW20 halfcut... it can be use on front wheel drive too.
And no need to find gearbox.
For 4AGZE information, stock boost is 0.6-0.7. Then if change to bigger crank pulley, you may boost up to 1.0 bar. For driveshaft, you may put the 16V/BT/ST or even C160 gearbox ar... It much better ratio, and it save on driveshaft too.
If want SC14 from Estima or Supra, i do have plenty of stock too... and just need recreate the bracket to able to use it only. Total mod = RM 1,000 on the road, we do all for you, and use back original intercooler too.
)??? Been interested in this MR2s since I was a kid... hehehe...
