How much for a k&n filter?? Anyone knows?? What other mods I can do for my car?? Btw, I'm not into styling, more to performence..
, but nothings impossible right?
. Pricing it all depends where you get them from... If youre into performance you shouldnt have started with a car designed for fuel economy hahaha, but nothings impossible right?
1. Air filter: K&N drop-in or open pod, up to you. It costs around Rm200-300
2. Exhaust: Go for a branded one if you can afford, change ESPECIALLY the header/extractors. They free up performance in your engine. Pricing it all depends where you get them from...
3. ECU tuning: Again, with good hardware you must have software to get the best out of it right? But i've got no experience whatsoever here so I'll just say try something readily advertised say, unichip? Or a reflash haha. Dont kutuk me yeah just trying to help :rolleyes:
Dont bother with nonsense like voltage stabilisers and that stuff, it BARELY works. I'm using one since I got it as a present and yeah... Go its worth getting other things :wavey:
All the best dude, have fun modding.
Newer car's nowadays all drive by wire but still can be modded what... Even the GTR for example.How much for a k&n filter?? Anyone knows??
since u mention u are looking for a simple mod...just go with voltage stabilizer. btw...guangdao really works. if you're into hard mods...can change the muffler, open pod, etc. but ur car is auto right....i recommend u to just change the muffler. if change extractor, decat, etc...u need a piggyback or ur car performance will become worst than stock car.
Why worse? Care to explain?:hmmmm:
1) if you change the extractor, remove the catcon, bullet and muffler....u will loose ur car's backpressure which basically comes from the catcon. so...less backpressure -----> no pickup
2) furthermore if you put in open pod....more air will come in and you need to tune back ur A/F ratio with a piggyback. more air but less fuel to burn is no use plus ignition timing needs to be adjust too.
that's why if you're looking for a simple mod...just change the muffler for an auto car. don't remove the catcon so that u will still have ur backpressure.
i'm not a pro but if i'm wrong hope someone can correct me. thanks.
.well bro ... try check it out at hc3msia.com ....currently ...i just installed 2 pt ur front bar and 16mm anti roll bar ... these 2 bars does alot when comes to cornering ....stable enuf to counter them ... talking bout air filter ...i got mine k&n drop in for rm250 exclusive of the cleaning kit dat cost around 55-70.... dats for performance ....no one dare to change into open pod yet .... talking bout muffler ..alot suggested to have a straight flow muffler... those good qualities like m7 or n1 trust further more if got budget can get the beat max t1 if not mistaken .... or exterior there r only few types in malaysia compare to thailand which there is alot ....here we have d mugen rr ...modulo.. airmaster and mugen ... i m using the mugen side skirt and back bumper ....my front is custom by rexxstyling... come join hc3msia.com ... theres alot fun out there ... cheers bro
