- Joined
- Jan 8, 2009
- Messages
- 376
- Points
- 1,528
Got some problem with my car. When accelerating everything is fine, but if sudden slow down from high speed, my car will stalling. What is the problem...
Previously what air filter you use? After change it, the problem comes out?What BOV u use?
1)did u do a timing belt change recently?please check the timing, also check the tune.
2)could be a vacuum leak somewhere, check esp the vacuum hoses going to plenum
3)check your throwout/release bearing.
4)check next time accelerate, then quickly release pedal(without braking), if stall(without braking) then its bov.
Do you want to try service the AAC ?
The following is what you can try as your situation is almost similar to mine:
1) Check your fuel pump.
2) Check your furl regulator.
3) Clean your injectors.
4) Have your tuner re-check your air fuel mapping and setting.
bov leak. try tighten it a bit.
do a diagnistics on ur car. last time similiar proble arise from my car , my TPS wasnt connected. ACC valve for rb 26 is underneath the plenum, a prick to open up. each ttime setting the timing belt need to reset idle. need to follow procedure recommened by nissan
How to check is the bov leaking?
Normally leaks at high boost. totally depends on luck. Just tighten a bit and se how it goes.
