Greddy Emanage, Ultimate & V-Manage
vale46
Kuching
Friends
I'm planning to install Greddy Emanage to my Proton Gen 2. Is it possible?
Well, there are quite a number of things to consider and one of it will be, is there anyone there who can do a proper setting for you!!!
For Mitsu 4G93P, it CANNOT work. I think basically, it may be some cross in the sensor settings that makes the "Check Engine" light to go on.
You can sms me at 017-8889518. will give u more info.
Emanage
Friends
For those who know how to install/connect emanage to the car ECU, please tell me. I got gen2 wiring diagam for the whole car. Just that I need to know which wire should I cut and connect to the emange. I need your guide.
just wonder, the new set of emanage will come with the software? and the cable to connect to laptop?
Who say cannot? Only the siemens ECU can't... mitsu wan can.
vale46 said:
Friends
Hey do you mind if i have a copy of your wiring diagram? i might be able to help in your emanage installation. Should not be much problem. Although i dont have an Emange but once i have the wiring diagram, i can work it out for you.
I need to know what do we need. I mean the sensors and connection needed like RPM signal ect. Give me those and I'll simplify it for you because the wiring diagram is about 100 ++ pages.
so.. whats the verdict?
so.. 4g93p can use e-manage or not? wanted to get one... now... not sure liau...
btw.. 2000 sgti is a mitsu or siemens ecu? my mech says from the looks of the throttle body and airflow sensor... its a mitsu.. can see like that ar? just wanna check...
thanks
i think....
if im not mistaken....gti b4 2000 use mitsu after 2000 use siemens ecu...
thanks
4G93P sure can use Emanage one. I fitted a lot oredi...
got money... can can go Emanage.
Waja oso can....
Kancil L2 oso can
Kelisa oso can
Kenari oso can
Myvi.... not yet having the opportunity to fit one.... so, cannot say more...
Waja oso can....
Kancil L2 oso can
Kelisa oso can
Kenari oso can
cipan, u own a tuning shop 1?
hehe, if be white mouse got special rate? :tongue:
Sure.... me too would like to know whether got problem on certain car or not... it's difficult to judge just from stories we heard...
Maybe there are some installation mistakes that make the setup unsuccessful... and after 1 try they gave up and start spreading rumours... which make the others afraid to try after hearing that 1 'no good' story...
can PM me ur shop and details? thanks... :biggrin:
If ur car running turbo and require more fine tuning, then probably emanage is good but then if it's stock as bone, i dont see the need of an ems... just a thought
emanage doesn't come with the datalogging software, it's an extra bundle that u have to order or purchase when u buy the emanage, same goes with ignition and fuel harness which have to be bought separately.... hope that helps
and the emanage ultimate is better but also more $$$... some of the good things that i can remember are two tune maps which u can switch between (street vs race/drag/whatever)... self tuning which hafta have the emanage map sensor or something(forget already), password protection...
how beneficial to emange & tune a N/A ride? with open pod + header + exhaust. or shouldn't really bother?
