Celica4AGTE20V said:zamans98 :
drag ah... i tried b4. the result not bad la. if u using silvertop 20v,i give u cheap setup first and then with upgrade.
-TRD metal head gasket 0.8mm
-blacktop camsharft
-blacktop ecu with MAP sensor
-blacktop piston with conrod
-blacktop four throttle
-6 speed gearbox with flywheel
-just polish the head will do, if porting too much, less vaccum (using stock ecu)
-racing spark plug, cable
-racing exhaust manifold
-power flow or 4 throttle
i guess this can make more then 170 kua.... for your futher upgrade, as list below:
celica,
which head r u refering to? Cause zaman mentioned on 20 svt upgrade for drag. Since the list of upgrade u mentioned have quite a lot of black top parts.
So, the head is svt or blacktop one?
Thanks....
