zamans98 :
drag ah... i tried b4. the result not bad la. if u using silvertop 20v,i give u cheap setup first and then with upgrade.
-TRD metal head gasket 0.8mm
-blacktop camsharft
-blacktop ecu with MAP sensor
-blacktop piston with conrod
-blacktop four throttle
-6 speed gearbox with flywheel
-just polish the head will do, if porting too much, less vaccum (using stock ecu)
-racing spark plug, cable
-racing exhaust manifold
-power flow or 4 throttle
i guess this can make more then 170 kua.... for your futher upgrade, as list below:
-racing flywheel, clutch
-progammable ecu, DLI or four coil
-high compression piston
-racing camsharft, valve spring
-adjustable fuel regulator
-more powerful fuel pump
-4 throttle trumpet
-racing engine oil and filter
dreamy: u tried b4? why it's not good for drag?
