there will be a big increase for 185 bodyparts... hehehe
oh... yes ah... so sad... :(Originally posted by krow@Sep 16 2004, 11:31
Levin92 has got the 185rc la thenOriginally posted by krow@Sep 17 2004, 15:08
thats an air water IC, u sure u bought the 185 instead of the 185RC?
i have a general feeling its a RC halfcut, unless its a 185 with a 205 engine.Originally posted by Levin92@Sep 17 2004, 21:07
im not sure thats 185rc or not.... :huh:
i jz know the halfcut almost like below but all keep standard except one air filter... :)
oh my god... :( my mechanic charge me RM1.6k..... :(Originally posted by kevinc@Sep 21 2004, 09:42
Range from rm1.2k - rm1.6k
Mountings are not a problem, just the massive wiring that requires lots of patience and time
i will transplant the dashboard into my corona..... b'coz its very nice compare with the corona one... :) i'll try to tell my mechanic to fix it nicely n tidy... :DOriginally posted by talam_buruk@Sep 21 2004, 09:53
just my advice .. find the mechanic then can transplant ur celica dashboard nicely .. and use the steering from da celica .. not like my mechanic .. "berserabut " the dashboard not tidy .. not fit .. need to cut some area at dashboard such the front air-cond hole ..
good luck ..
Originally posted by Levin92+Sep 22 2004, 03:36 -->
QUOTE (Levin92 @ Sep 22 2004, 03:36 ) --QuoteBegin-talam_buruk
@Sep 21 2004, 09:53
good luck ..
i will transplant the dashboard into my corona..... b'coz its very nice compare with the corona one... :) i'll try to tell my mechanic to fix it nicely n tidy... :D [/b][/quote] the meter of my corona jz till 200km/h... coz my one is 85's corona... :D so old old car... B) |
i'll use the st171 gear box... ;)Originally posted by kevinc@Sep 21 2004, 10:48
you can use back ur corona dashboard if u want to
since u wont be using the 4wd gearbox (sensor)
ur corona meter will fit well for a cabled gearbox
corona meter is much better coz it shows 220km/h rather 180km/h :P
no speedcut wif the 3sfe g/b
levin92, which g/b r u intending to use ?
Originally posted by krow+Sep 21 2004, 15:15 -->
QUOTE (krow @ Sep 21 2004, 15:15 ) --QuoteBegin-Levin92
@Sep 17 2004, 21:07
i have a general feeling its a RC halfcut, unless its a 185 with a 205 engine. [/b][/quote] now i think i can sure my halfcut is st185rc b'coz the turbin in used is CT26... :D really happy if its a 185 with 205 machine... :D but its not... :( B) B) B) |
Originally posted by Levin92+Sep 22 2004, 03:48 -->
QUOTE (Levin92 @ Sep 22 2004, 03:48 ) --QuoteBegin-kevinc
@Sep 21 2004, 10:48
i'll use the st171 gear box... ;) st171 g/b is 3sfe or 3sge??? izzit the mr2 g/b also fit to my corona??? :huh: [/b][/quote] st171 g/b is 3sfe (final gear 3.75) your speed will be something like.. (5th gear) 80km/h @ 2000rpm 125km/h @ 3000rpm 165km/h @ 4000rpm and so forth.. yes, mr2 g/b will fit |
