What is an "AP Engineering model" and do I need it?
"A.P. Engineering Original Power FC units carry the same functions as the regular Power FC units but have been specially adopted for use on car models that the regular Power FCs do not cater for. As they are an item outsourced from Apexi, their pricing is higher than the regular models." -
www.greenline.jp. An example of an "AP Engineering" model is the PowerFC for the r32 gts-t.
What is the "D-Jetro" model and do I need it?
The D-Jetro Power FC units carry the same functions as the regular Power FC units but do not require the use of the factory standard air flow meter and use a mass air pressure sensor. Apart from the unit itself, use of the D-Jetro units requires additional parts that vary depending on the model." -
www.greenline.jp The airflow meter (at least in the skyline range) does not pose a big restriction in terms of horsepower and one would doubt the use of the D-Jetro. If you really need massive airflow you can always change to 2 x Q45 Airflow meters and use those with the PowerFC. The skyline series are optimized for closed loop operation with an airflow meter and oxygen sensor for feedback and measuring. Cars the run on a MAP sensor system can suffer drawbacks such as bad idling, poor fuel economy, problems with cold starts etc
What is the "Power FC Pro" and do I need it?
The Power FC Pro Spec.CPU has been designed for drag racing use. These units have two additional functions over the regular units: 1. Ignition cut used for rpm limiter - Regular Power FCs cut fuel feed when the preset revolution limit is reached. At high rpm, there is the possibility of knocking when the fuel is cut in high-powered cars. The Power FC Pro CPUs cut ignition at the rpm limit to prevent the knocking that could potentially destroy the engine. 2. 0km/h rpm limiter setting - Allows for the setting for an initial rpm limiter that is active whilst the car is not in motion. This allows for mainting a rpm level for consistent launches.
Is the PowerFC Pro Discontinued?
Apexi have discontinued the PowerFC Pro model which was the special version of the PowerFC that had IGN cut instead of Fuel cut and also had a REV LAUNCH function holding the rpm at a set value at 0km/h. For some cars the PowerFC Pro model exists (RB26, RB20, WRX) but for most models it has been discontinued. Apexi have not released any information as to why the model's have been discontinued or if there will be a new model coming out. Those customers who must have the Pro models should look for a 2nd hand unit instead.
Does the PowerFC run the whole car or do I need controllers for things like Aircon, Lights etc now that I've removed the factory computer.
The PowerFC emulates all the functions that your standard computer did. This includes things like Aircon, Lights, ABS etc
