clutch problem..i suppose
KaiKon
Hi all,
got few questions here, 1st,whenever i`m in 1st gear or in reverse, there`s a 'hissing' sound coming from the engine,one mech told me its the clutch bearing., really aa? 2nd, when my car is on un-even surface i cannot start my car, it will go dead.. could it be the fuel pump?roughly how much for b16a fuel pump?or can i fit a b18c`s? 4 the record,im using b16a standard...
thx in advance...
Mister potato snacks for RM1.80.. good buy..
Kidding! Ha ha ha.. :P
Anyway.. what kind of hissing sound?
rm880?huiyo..no thx bro...shiro,i dont know how to explain what kind of hissing sound la, but its noisy..and does clutch have a bearing?and last time i tried someone else`s clutch,its much lighter than mine.
if it makes a noise when you push the clutch in but not when its out then it is the clutch release bearing, if it makes a noise while in gear but not when you press the clutch pedal in then it is the input shaft bearing
input shaft bearing ey?do u guys know how much would it probably cost?can i just replace it or need to buy a whole set of sumthing?e.g clutch?
you should let your mechanic verify the problem first, assuming is not a good idea. there could be other problems related to it. by hook or by crook the gearbox has to come down.
localStorage.removeItem('xenFHideSidebar'); } }); }); $(document).ready(function () { 'use strict'; $('#gece-modu').on('click', function (e) { e.preventDefault(); $(document.documentElement).toggleClass('gece-modu'); if ($(document.documentElement).hasClass('gece-modu')) { localStorage.setItem('xenFDarkMode', true); $("meta[name='theme-color']").attr("content","#090909"); } else { localStorage.removeItem('xenFDarkMode'); $("meta[name='theme-color']").attr("content","#202020"); } }); }); $(document).ready(function () { 'use strict'; var aktifYukseklik, currentScrollTop = 0, header = $('#xenF-header'); $(window).scroll(function () { var scrollYukseklik = $(window).scrollTop(); var headerYukseklik = header.height(); currentScrollTop = scrollYukseklik; if (aktifYukseklik < currentScrollTop && scrollYukseklik > headerYukseklik + headerYukseklik) { header.addClass('slideUp'); } else if (aktifYukseklik > currentScrollTop && !(scrollYukseklik <= headerYukseklik)) { header.removeClass('slideUp'); } aktifYukseklik = currentScrollTop; }); }); $(window).scroll(function(){ if ($(this).scrollTop() > 50) { $('#xenF-header').addClass('headerShadow'); } else { $('#xenF-header').removeClass('headerShadow'); } });
