BluecluBBy said:
Hi donCityZ
Please do more online study and check the response rate of supercaps compare to your electrolytic caps and you will know what i mean.
In fact no one is silly enough to install such thing near exhaust manifold.
Those diy of yours is not done right as you are not using the correct type of caps for the job and single value caps only does it's work on certain harmonics.
Your configuration is not for refine electronics and more of a power bank.
Regarding spark you're right if you light it one at a time but if the engine cycle reach higher RPM then it does really matter.
Do read more about dwell timing for ignition, that split seconds for spark is very critical.
Let put it this way: RO , Filtered , Distilled water does actually taste different but to the general layman ..water is water...
yo clubby,
it dont matter what it is called. super cap, what cap.. it is still a ecap. ya, for filtering it depends on what value of each capacitors... but then, how would u know whether it fits ur car if u just simply buy it off a accessories shop rack? unless u can test each of the products(with different combination of ecap values) by monitoring the battery voltage at different rpm ranges using digital osc, then its no point spending so much $$$ on it right? how u know those VS fit for all type of cars? different cc also... some even use high perf camshaft or such... all is different.
Your analogy is not applicable here. RO water and filtered water are TWO different things. Meanwhile my analogy compare two SAME thing... both are fuel...
in same cup.. only the thing that ignites it is different. If u want to use water as analogy, then make it 2 glass of RO water being drunk by 2 different person. then, the result is same right? the person may taste differently, but the effect of the water on both person are same right?
if u want to improve spark to ignite each cycles, its enough to use good quality plugs and tune the ECU .even low resistance plug cables are useless...
maybe u already spent gajilion RM on those products (VS etc etc) and wanna make urself feels better... i dont blame u for that.... hehe... but i just want other ppl to spend money where the REAL POWER INCREASE comes in. Like extractor, muffler, center box, air intake and such. VS, ground cables, low resistance plug cables basically does nothing, especially to new cars.
