- Joined
- Aug 27, 2004
- Messages
- 1,309
- Points
- 3,148
Originally posted by cyclonite+Feb 27 2005, 00:26 -->
QUOTE (cyclonite @ Feb 27 2005, 00:26 ) --QuoteBegin-saru-kun
@Feb 23 2005, 19:34
rev matching
a technique done during a downshift to prevent the "lurch" when the clutch is let off
- clutch in
- drop down a cog
- blip the throttle
- clutch out
I wouldn't do it like that. I would change the sequence to.... - clutch in - push gear into neutral - blip the throttle - drop down a cog - clutch out Simply because I always believe it's better for us to rev the engine to match the revs rather than using your synchromesh to match the revs for you. That's why I always rev in neutral before engaging the gear in. [/b][/quote] Cyclonite my fren, use heel and toe lah... no need to double declutch wan. |
. Couldn't find the parts for CS3A in the...
