msj92 said:
Yaumolo. F.Y.I grounding cable have thin wire inside so it have high resistance. We have to know that resistance will be high if.
- the wire is thin. so that the thicker wire have less resistance
- longer wire. so that the shorter the wire have less resistance
- type of wire. cooper have less resistance than zink or other metal
the most suitable wire is gold. tapi sapa nak pakai .
if want more info pls refer to DREXCHAN website.
The first two point i agree, coz is base on resistance formula:
R = pL/A, (R-resistance, p-resistivity, L-Length, A-cross-sectional Area)
But ur third point got problem, if compare copper and gold resistivity, we know:
copper resistivity is: 1.7 × 10^-8 (ohm metres)
gold resistivity is: 2.44 × 10^-8 (ohm metres)
Material that are good electrical insulators have a high value of resistivity.
So, copper resistance is less than gold at the same condition.
(Weight, area, and length)
"Bukan tak nak pakai for grounding cable, it's bcoz unsuitable.
Actually, suitable material for cable is "Silver" (1.59 × 10^-8 ohm metres). But expensive, normally use for "HI-END" sound system".
But Gold got one advantage is stable and no easy oxidize, that's y normally use for plating connector, or cable terminal.
Share share :tongue:
