H2Zero said:
What u ordered and received is not an entire stand alone right? Its more a piggy back to your existing system. I believe a complete stand alone is much more....
maybe you don't understand what is piggy back and what is stand alone?
piggy back ecu is modify your map or airflow signal and iginition siginal to cheap original factory ECU.
MS is not piggy back. it can't take input from map or ignition and modify to cheap original factory ECU. but it can act like piggy back. you can ignore the spark control, and drive any injector to do fuel only. leave the spark control by original ECU. or reverse, control the spark only, leave the fuel control by original ECU.
for example, emanage. after you install, you never tune it, leave the map zero. the car still start and run like original. cause what signal going into emanage will going back same value to original ECU.
but MS can't do this. if you didn't tune it, it won't start or run properly. you need to create your own fuel map start from zero.
MS1 is better then haltech E6k or similar .
MS2 support not as good is MS1 cause it still new, not much people develope yet. but the CPU is faster then E6k and E6X. i have try adaptronic, its faster then adaptronic 16bit CPU. plus, it can run close loop, with auto mixture. mean you it can tune it self when you drive. this already better then microtech, haltech and other market stand alone. so far i know autronic, motec can do this.
