Good job taiko!
Zenn said:either monoblock or 2ch also can as long as meet your power requirement and impedance...and budget
Gti said:And btw bro...
i checked out in their web that the optimum power is 300w.
Should i provide more power than the optimum power recommended?
bcos if i am not mistaken i seen before that for a mid range speaker...we should provide more power than the power required...
am i correct?
the more power can make the speaker feeling more fierce.Gti said:And btw bro...
am i correct?
oldskolboyz said:Which 1 bro.. JLW6 or JLW6V2.
If JLW6 discontinued production long time ago.. since 2001 after JL intoduce JLW6V2 in that year.. JLW6 ori is DVC '6+6Ohm' 300wrms, 'beware fake product' loor.. U need monoblock 300-400wrms at 3Ohm technically loorr or above 600wrms at 12Ohm (A/B) woorr....
Pegasus_waja said:the more power can make the speaker feeling more fierce.
but before that u need to scooping for the speaker if not there will be overload.
my mid range speaker handling power is around 80-120 but i use more than 250watts to push it
am i correct?
Gti said:hi1983 : care to explain more bout the meaning of damping factor?
oldskolboyz : i still dun understand bout what is scooping....
Zenn : if u say double the optimum power is good....does that means i will need 600w rms from my amp or something like that? Cos...i dun really understnd all those 'ohm' stuffs la....can put it in simpler term?
appleyard : what is play with box volume?
sorry ar all sifu....still trying to learn....
Gti said:can i ask how do we do damping on the amp?
can it be DIY?
or it needs to be done by pro installer?
Zenn & appleyard taiko: if u say we feed it at 500w rms...that would contradict with what appleyard says....1\4 of the recommended rate.
Or issit diff school of thought?
or had i misunderstood anything?
appleyard said:1. Yes you can if you are an amplifier manufacturer. You can set what how much damping you want. But if you are not then its suppose to come with the amp like a package.
2. What I meant is if you have a sub with 500w rms you wouldnt want to power it more than 625w rms (rule of the thumb) unless its proven that the sub can withstand the abuse and you have good ventilation of the voice coil. But thats also depended on application. Sealed has poor cooling system for sub. Ported are efficient and if you push too hard you'll get a blown sub. There are a lot of variables to be considered but play by the rule if you are not sure and stay with the RMS rating.
), MME Sepang J's Racing review...
