thank you for the help...will check it out...
you also might wanna check from Mugen distributor (Kingcrimson) in singapore on availability of the lip. Here's a link to my blog : The Black Mamba: Santa Came During Raya!
hi everybody, mind i know what is the normal oil temperature for ur guys dc5s? how abt the highest? should be around?
---------- Post added at 08:13 PM ---------- Previous post was at 08:12 PM ----------
anybody here installed oil cooler? does it help a lot? price?
oil cooler with minimum piping doesn't affect the oil pressure much.
not really any noticable effect, but definately helps with the oil temp (logically !)
but problem is , the stock engine for DC5 already takes up about 4.5 liters of oil.
with the oil cooler + piping , it goes up to 5.5 liters to 6 liters , so your maintenance/servicing cost goes up.
good thing about it is, well, due to the cooling and circulation, the oil remains "fresh" for longer, i guess
also, remember to use CLAMPED (locked) hoses (not sure if that's the right term) , dont use the normal rm2 clamps, sure bound to be leakage.
also when installing, careful with the hose scraping, if your car is significantly lowered.
hope the above helps![]()
Need help regarding my ecu issues, plug an aftermarket ecu n my car won't start because of the immobilizer thingy. What can I do? Tried 2 different ecu.
i do have a oil temp gauge...but it's always at around 90++ when normal driving...when v-tecing ...sometime it goes around 110..damn hot!!
Where can we get the additional harness bro? A new thing occured with my car today... There's a click click sound when I press the clutch paddle...haiyo..hehe
