ARTA said:er...btw, u can check with other forum and engine spec website , B16A1 from EF and DA (except for the auto tranny) has dual springs on the intake and single on the exhaust :)
Cheers!
ARTA said:Auto tranny only come from an integra (DA), I got my engine previously from an EF8 halfcut. When i dismantle the engine, i found out that there's dual springs on the intake and single on the exhaust. Also, u mentioned that u r changing B16B cam coz it has dual springs? Changing the cam won't give you dual springs :) Auto tranny is not meant to rev high, so the cam that come along is weaker at higher rpms.
Cheers
Cimpeng said:hahaha...lantoiii...
that one not because of rechip lorr..
that is because of kedai salah bg comp. box..
not because of rechip k... :D
but me...yes rechip...perhaps can test this nite?
:D
btw..we r ORI EG9...not conv. one...no pening² kepala wana change rear bonnet+rear screen+black panel+etc... :D
any comment about this??
BlueG said:Getting something already complete is no good for me. I rather than buying something incomplete and then make it complete. Its can be consider as a hobby. You can feel the syiok when you found something which is very rare and install it to your car ... If you buy a complete car then got nothing to do after that then no syioklah ....
Lagipun not all inside ori EG9 is cun ... muahahahaha .... :D
syiokk?? hobby?? very rare item??
i think all r u using in ur car is come from ORI EG9..
u play to makeup...me EG9 play performence.. :D
so which one is more syiokkk???
ahaks!!~
btw..getting ORI car is more mening..no pening² kepala.. :D
BlueG said:What I meant here is that original B16B has both dual springs for intake and exhaust side. So if I want to use the B16B cams, then I have to modified my exhaust side by using dual springs. :)
isn't that your EF8 halfcut last time was 'not-stock' ... modified from Japan summore ha :DARTA said:Auto tranny only come from an integra (DA), I got my engine previously from an EF8 halfcut. When i dismantle the engine, i found out that there's dual springs on the intake and single on the exhaust. Also, u mentioned that u r changing B16B cam coz it has dual springs? Changing the cam won't give you dual springs :) Auto tranny is not meant to rev high, so the cam that come along is weaker at higher rpms.
Cheers
