Having some problem on my Uncle car:
My uncle car is Honda Accord SV4, 2.0 SOHC (standard), and Automatic.
1. when turn the key to ready mode, the auto indicator D4 & P light was turn on but the actual gear is on P. When start the engine, the indicator D4 will be off.
2. Morning start the engine and push the gear to reverse, the car won't reverse. Unless you push it forward few time and try again, it will able to enter the reverse mode. Or else let the car heat up itself about 5 minute, then it be will able enter to reverse without any problem.
3. brake lamp indicator light on. I do check the brake pad no problem, brake servo no problem, test braking also no problem, even hand brake test also OK.
4. when compressor is start working only, it will have a funny sound come out. When it on operation or stop operation, no sound at all.
...now..it's time to thank for a good work done by Kit and his crew...Well, I have to...
