taikor...heheh...no need so mahfan....just let me know what i need to do to make my car less oversteer ....
This is what i gather from some forums, i hope this will help a bit:
Spring Rate Changes:Decrease front rate only
Effect on Suspension : Front ride rate decreases. Front roll resistance decreases, decreasing understeer or increasing oversteer.
Antiroll Bar Changes
Increase front rate
Effect on Suspension : Front roll resistance increases, increasing understeer or decreasing oversteer. May also reduce camber change, allowing better tire contact patch compliance with the road surface, reducing understeer.
Shock Absorber Changes
Decrease rebound rates only
Effect on Suspension : On bumps, tires follow track surface more effectively; car may continue to oscillate after bumps.
The Importance of Tire Temperatures
In the course of testing the handling of a car, use tire temperatures and driver feel to make adjustments. It is critical to monitor tire temperatures often. They offer valuable clues to the setup of the car. The areas of adjustment that tire temperatures are used for include: tire pressure, camber, body roll, shock settings, wheel width and transient handling response.
Reading:Front tires too hot
Handling problem : Understeer
Troubleshooting Tire Temperatures : Front tire pressures too low.
Solving Handling Problems
The key to setting up your suspension is in diagnosing what the handling problems are and resolving how to fix them. While car enthusiasts often baulk at the "black art" of suspension tuning, there's no reason to. As with working on the mechanical aspects of an engine, the trick to suspension tuning is in the troubleshooting; there is always a cause and an effect.
Problem : Steady state understeer
Manifestation : High-speed turns only
Solutions : f front tire temps are OK, increase front downforce.
If front tire temps are too hot, reduce rear downforce.
Problem : Corner entry understeer
Solutions : Front shocks are too soft in bump resistance.
Too much front toe-in; use a small amount of front toe-out.
Problem : Corner exit understeer
Solutions : Rear shocks are too soft in bump.
Front shocks are too stiff in rebound.
Problem : Straightline speed too slow
Solutions : Too much overall downforce.
Too much toe-in or toe-out.
Ride height is too high.
