How to
Really built a car, a insanely built monster car, stripped down to the bone.
original car
http://www.5di.ca/mrs2.jpg
stripped
http://www.5di.ca/pics/1.jpg
towing
http://www.5di.ca/tow2.jpg
http://www.5di.ca/pics/5.jpg
http://www.5di.ca/pics/Block1.jpg
http://www.5di.ca/header3.jpg
http://www.5di.ca/e5.jpg
the list;
List of mods (atleast what he can remember), not including the hundreds of small things that he custom made for this car.
Engine/Drivetrain
2zz engine
Supertech Valves
Darton Sleeves
Eibach Valve Springs
P&P head and intake
Ignition Solutions Plasma Coil Packs
CP Pistons
Crower Rods
Hyra Nemesis ECU (MAP sensor)
WBO2 sensor
B&M Oil Cooler
Aeromotive Inline Fuel Pump
Aeromotive Fuel Pressure Regulator
FIC 525 Injectors
Fuel Pressure Gage
S/F Fuel Rail
Circuit Worx Oil Pump
koyo radiator (no limit)
Custom made header (thanks Derik)
Custom 3" exhaust with magnaflow race muffler
Custom baffled oil pan
Aluminum aeroquip fittings and SS braided hose (more then you can imagine)
TRD engine mounts
Custom block guard
arp oversized main studs
arp head studs
Autometer Boost Gage
Autometer Pyrometer
Denso Iridium Spark Plugs
Golden Eagle Vacuum Manifold
Fuel Safe SM108A Fuel Cell
Turbo/Intake
GT28RS Turbo
BOV (turbo xs)
4 psi Wastegate Actuator
Profec B Spec 2 Boost Controller
Custom Raditor/Heat exchange for IC System (tops radiator)
Custom made aluminum IC reservior
K&N cone air filter
Jabsco Water pump
IC Silicon Elbows
Spearco w2a 2-231 I/C
Tranny/drivetrain
Fidanza Flywheel
RPS Clutch (6 puck)
2000+ Celica GT-S Axles (stronger then stock mr2 ones)
TRD Clutch Type LSD
TRD Short Shifter
speed source bushings
speed source extended clutch rod
Speed SOurce SS clutch line
Body/Wheels/Interior
00+ Celica seats
Fiberglass Trunk 9lbs
apr bodykit
apr wing
apr mirrors
TRD Hard Top
CF Hood 11 lbs
Sony cdxm9905 head unit
Racing Hart C4 18x8 front and 18x10 rear
BF Goodridge KDW2 Tires (285/30/18 rears, 225/35/18 fronts)
Brakes
Carbotech Panther Plus 1106 brake pads
Stoptech brake lines
Stoptech brake rotors
Jeg's Vacuum Resurve
Brembo Rotors (OEM size)
Speed Bleeders (all calipers + clutch slave cylinder)
Suspension
JIC Magic FLT-A2 Coil Overs (including pillowball mounts/camber plates)
cusco bushings (phereical bearings front and rear suspension)
Breatplate (by corky)
Toms braces Complete set
TTE Sway Bars front and rear (3 way adjustable)
Energy Suspension Front and Rear Poly Sway Bushings
High and Tight Rear End Links
Custom made front end links
Other
Odessy Battery (12lbs)
Solo 1 legal 4 point roll bar
4 point harness
http://forums.c7performance.com/showthread.php?t=11979
