wah sifu chin wan play with straight cut dogbox liau ar? that quaife one no need high final drive liau.. already close enough XD 5th gear 1:1 ratio... me no skill play with dog engagement gbox wor..
Blacktop20V said:It cost me around RM7k inclusive of turbo, piston, 4EFTE upper block, full over-haul, exhaust and turbo acc. eg. BOV, manual boost controller, etc.
Actually all tranfer from 4EFTE engine and I only use back my lower block due to JPJ hassle free.
Good luck
guest18 said:which is cheaper ?
turbo charge a 1.6 4efe
or
up the cc of 1.3 4efte to 1.6
i did abit of research last time when i crazy about dog engagement straight cut gearbox, can learn abit more about them, and probably enough to "imagine" how they would feel like:Acoustic said:actually I don't know the feel of straigth cut, only think close ratio enough.... but no money ah, dream dream lah :)
http://www.sdp-si.com/D190/HTML/D190T50.htm
hahahaha.. really have to tepi tepi sikit liau.. cuz you never know when the ke70 will fall apart with svt/bt insidesbirdz said:KE70 or LE + svt'd hahaha.. Seg svt bt also have to ketepi la..if see them roaring behind like ikan laga.. some more all sensei's car is FR ones.. lagi ketepi la.. hahha!! ^_^
btw the 4efte above issit 1.3cc starlet engine or 4afe plus t r? :D
Seen SEG with starlet turbo engine but.. never really go and drag with da fella.. pickup..turbo so aiyer.. already know and aspected.. but top end?
everyday i drive car also scarycorollagtouring said:5k? 3SGTE la bro.....
after put it into your engine bay....
215/225 or 245hp gains, depends on your taste
If u buy supercharger... 165... turbocharging it needs more work... maybe extra 5k...
same as 20v turbo....
kacuk 4EFTE is OK but.....
3sgte is a ready-for-war.....
you won't have to upgrade anything unless you wanna play with EVO.... hmmmmm....
my vote: 3sgte..... if u want a swap and powerful....
cos if u use a 4agze or 4AGTE...... the 3SGTE it self are prepared by Toyota.... so reliability is not an issue.... upgrading means more RND.... RND mean Funds.... Funds mean money... Money mean No Fun at all..
me? sticking with 20v SVT cos the parts are easily found..... cheap and reliable too....
in the end it just depends on your driving taste.... some prefers NA, some loves Turbo... some loves stock... I used to use turbo but switched to NA cos it is more controllable and I love the power curve...
4agze_gt said:bro corollagtouring, u have my vote.
go for 3sgte la if u wanna play turbo. oem eqipped turbo from toyota. the engine comes from toyota celica gt4 model.
http://www.japanmotors.co.uk/images/1994%20celica%20gt4%20silver%20engine.jpg
watch out for this fella guys, he's got one hella monster in his way...heheheeh:shades_smile:
what you mean? if you mean the displacement then its 2.0liter not 1.8.samuelccy said:okie okie .. tht means is 1.8 le ... how bout FC ah ? .. would it b very high? n how much would it cost me ?
rollakid said:what you mean? if you mean the displacement then its 2.0liter not 1.8.
fc ar? hmm... see how heavy is your right foot![]()
corollagtouring said:Fcut price?
3SGTE- maybe 3500~4500
4AGE SVT- 1800~2500
4AGE BT- 2800~4500 depends on transmission and mileage
4AGZE AE101- 2500~3500 depends on modification.
but better spend big at one time....
cos
if u buy cheap FC... like 4agze.... maybe you will:
1) change manifold- 1000
2) change to turbo- 700
3) turbo oil lines- 300
4) ECU need to mod- 1800 (greddy emanage)
In the end, better put 3SGTE cos no mods needed.... already 215hp,225hp and 245hp ready to whoop your ass....
and you can upgrade your 3SGTE much more than you can on a 4AG... if the hp is your measurement that is
corollagtouring said:yes bro, and what more important is you won't have to worry if u mod your 3sgte... cos the internal can stand higher abuse...
If putting 4age... there will be restriction to internal strength.... like if u wish to climb above 250hp... maybe you should reconsider to put forged internals... in the end... 3sgte is the best option....
and because the 3sgte is already powerful and will over the power to weight ratio.... you may need no mods.... if u are using 4agte or etc etc... upgrading means more mods have to be done to the ECU system.... u know how much a microtech costs.... at least the SAFC.... have to be used.... and you need to find the best setup.... not too lean or rich.... then at this point.... major problem can happen... piston blow, con rod bent etc etc......
but i dunno whether the handling will be stable is putting a 3sgte.... cos the highest cc for a corolla is a 3SGE corolla... no turbo... me? i like 4age cos i can still manage my ponies at high speed.... how about you?
