well...there's is 2 types of so called 3 way active xover...howiechoo said:just ask to confirm:
1 got 3way active crossover, then i connect it to a a for tweeter, i wtill need a passive crossover?
1 is the 3 way which is
-front highpass
-rear highpass
-subwoofer control
the other 3 way active is the real 3 way...which is
-tweeter highpass
-highpass of bandpass
-lowpass of bandpass
the above 2 r the same...bandpass 4 the mid
-woofer...
if urs is the 1st 1...u still need a passive...if u tap it straight then ur mid will produce high pass onli...
if urs is the 2nd 1...then its ok 2 run witout passive...
set the tweet at 2.3khz..mid at 2.3khz-70hp n woofer at 70hz also...then tune it ur way 2 ur liking
