now running standart svt...if wan to cnvrt to map..wat i need..bt wiring & ecu only or another part from bt needed...
dunno, but i've seen people running svt with bt ecu but svt throttle body and dashboard. and at the begining of my transplant, which i use an svt manual but with auto wiring, and svt's auto wiring go direct into bt's manual ecu, plug and play, just use a map sensor thats all -__-" not sure lar but thats what i see when my mech is transplanting the engine.swap aka SWAP said:Why some ppl said need bt itb or trotle body...how abot dashbod wiring..
cusco said:SVt auto ecu socket same as BT but i doubt it will the same pin designation as the BT ecu,but never check on this
maybe he want to run open throttle..EG9 said:you need BT wiring(complete set) and BT ECU. That ALL. As for the vacume line, you can tap it out from SVT ITB as well.
But why do you need to convert from AFM to MAP?
I still prefer my car power during I'm using AFM with TOM's ECU (stock BT engine). Much powerful then current BT standard ECU with racing cam.
oh~ the sound...
