help!! my 20v idling problem!!
cronixz...my situaition is TERBALIK with u!!my rpm goes down to 500rpm:burnout:
my car oso got noisy DIESEL sound...maybe it was TRADEMARK for 20v。。lol
alex:
yea the diesel sound is common thingy in 4age as i herd in many forums and frenz.. haisss...this issue is js not resolving.... hav to change mounting as well... aredy loosing lotsa $$$.... lookin into priority 1st...
Alex - try to adjust your VSV for A/C Idle-up using an allen key...look like in the picture given below...normally located near the firewall next to the wiper motor...
i tot its called FICD
:biggrin:
living with same problem for few years already. normal idling : 400rpm with a/c 800rpm
sometimes engine choking below 2k rpm in 2nd gear..
all sifu ? mind to ask question ?
1)currently my car's expension tank must top up a bit water every single week.. the
expension tank level when cool time will at min-line then top up to max -line level for a
week!... izit normal for the 4age engine ? seem like the 4age hotter compare to other car
!? or my car got some problem d ?
2)after 2000 mileage engine oil will reduce abit when ramp n drive fast ! but if normal
condition driving for 5000mileage, engine oil not reduce !?... what is this issue ?!
engine oil = wyne 10 40W + blue chem oil system care
any sifu can share some knowledge !?
try to check ur steering rack vacuum hose, if tertanggal or poor hose condition will cause the problem u mentioned..
if everything tried, it's time to change blacktop wiring running MAP...hehehehe!!!
I realize my steering rack oil seal is kind of leaking .. but very small leakage... could it be due do that???
Already solved this problem after running on MAP...
use back svt ori wiring can kah? how long u doin tat? any problem? can share cost n where to done it? thx:biggrin:
yes bro. use back SVT wiring. Forgot already how long to do it. maybe only take a day or two. I do it at my house. DIY. Hehe. So no cost for workmanship. So far use it with no problem
kimi,
can u help me to do that?....i can pay back the money to u...
feipepe, are you using auto wiring? If you do sure i can make it for you, but if you is using manual wiring, there is a bit problem coz ecu socket didn't match
kimi,
thanks for ur prompt reply, in fact, i using svt manual...u meant the ecu socket not match? is that need to changes the ecu to blacktop? if not, how comes can't used back the svt socket? if i not mistake, svt manual socket are sames with svt auto...
...... if i not mistake, svt manual socket are sames with svt auto...
They are diff...
M/T is 26p-16p-12p
A/T is 26p-16p-22p
For BT's, both M/T and A/T are 26p-16p-22p
Some interesting project yeah... :biggrin:
Remember to solder & isolates the socket's pins properly.
Like Mr. Levin said, it's different.
SVT manual pin is 26/16/12 but BT (auto&manual) are 26/16/22.
The problem is for the third socket. If solder it, it will be bigger problem to remove if the ecu got problem at future.
As for me, I just put single wire to each pin without socket so that ecu can be remove.
But it's my car and if something happen I know where I have to look to.
Unless u can find 22 pin to replace the 12 pin.
