Sam-Q
how did you end with such a high compression ratio? did you shave the head?
or perhaps the better question is how did you measure it?
I also don't know the exact process of how they balance an engine and I am also suspicious because if you send your parts off you can see drill marks but if they assemle the engine who is to know?
I think you will find if you measured your engine it would be 10.5:1, it won'tbe over 12 unless you shaved off something like a whole mm
Veloc: blacktop rods although tiny compared to silvertop are still very solid compared to other rods and I see it being quite unlikely that any level of boost would cause them to bend. Revs kills rods unless it's an engine with a very low redline originally and has miniscule rods to suit it. The local to where I am Ford turbo 4L 6-cylinder is a good example of that. So they had the right intentions but probably an un-nessesary step. Also it brings up the issue of piston stength.
so did you actually measure the chamber size with burette or your just estimating where it's at?
