bro E-tech, please pm me your name, hp number and full address.....will sent a P30 ecu to u for repair......thanks
Siauann
Ecu located at front passenger side.
Side panel under the console.
Remove the side pastic cover and you will
Be able to see the ecu...remove some screws
And ecu can be brought out.
Number is at the side of the ecu...
i manage to remove the ecu and check before cny while cleaning the car.
37820-P2T-J91
does this affected?![]()
Hi bro.. Mine is a Hondata s300 bundled Ecu. Bought brand new from authorised Hondata dealer It is still basically a obd1 ecu brand new equipped with the s300 fitted all by Hondata themselves. So am I affected?
hi guys any other components I need to check if ecu cannot turn on fuel pump..
i replace caps. ic17 and ic12
Qm3 replaced?
yes QM3 replaced..
car wont start CEL wont go off
no fuel pump ON[/QUOTE
Need To check ic17 again or the copper trace to ic17.
Bro, how much it will cost me to replace all this capacitor inclusive labour, fyi i drove yr 99 civic..
yes..how muchh cost?this only p30 or others p72 or p08 have the same risk?
I am looking 37820-P27-T01 for my civil car.....
yes QM3 replaced..
no fuel pump ON
thinnaph....
remove J1 and let us solve the solid cel first.
have u tried to find out the error code?
btw u using the P27 for what enjin? Sohc?
