One more doubt I have is, our pv6 engine is 6a12 DOHC right? Why is it only 148hp? Which is the SOHC 6A12 engine..
6A12
6A12 MIVEC V6 fitted to a Mitsubishi FTO
Displacement — 1998 cc
Bore — 78.4 mm
Stroke — 69.0 mm
[edit] SOHC
Engine type — V type 6-cylinder SOHC 24-valve
Compression ratio — 9.5:1, 10.0:1, 10.4:1
Fuel system — ECI multi
Peak power — 107–110 kW (145–150 PS; 143–148 hp) at 6000–6750 rpm
Peak torque — 179–181 N·m (132–133 lb·ft) at 4000–4500 rpm
[edit] Applications
1992–96 Mitsubishi Galant/Eterna/Emeraude
1992–94 Mitsubishi Diamante
[edit] DOHC & sports ECU
Engine type — V type 6-cylinder DOHC 24-valve
Compression ratio — 10.0:1
Peak power (1994–1996) — 127–132 kW (173–179 PS; 170–177 hp) at 7000 rpm
Peak torque — 191 N·m (141 lb·ft) at 4000 rpm
source :
Mitsubishi 6A1 engine - Wikipedia, the free encyclopedia
At this source it states that the DOHC engine has 170+ hp.
Could it be our auto tranny eats alot of hp, or the facts on this wiki is wrong?
Anyone ever dyno a manual pv6 manual transmission before?
