Today update for the RB30 PS-Response Program
http://a8.sphotos.ak.fbcdn.net/hphotos-ak-ash3/s720x720/563312_357366160965985_323914650977803_925397_703224203_n.jpg
Even though this newly built RB30 short block already being balanced and rebuilt by other workshop. But we want it to be the best it can be, so our perfect counter-check primary balancing is absolutely necessary. Real engine balancing helps an engine run smoother with less vibration which creates less havoc on main bearings and helps engine last longer.
http://a1.sphotos.ak.fbcdn.net/hphotos-ak-ash3/s720x720/546516_357366834299251_323914650977803_925400_511196137_n.jpg
The rebuilt & machining jobs of this RB30 already done by other workshop, so the only problem with us is that no blue-print can be applied to this engine. ‘Blueprint’ means following a set of specs to the "T". For instance: A blueprinted set of engines will have EXACTLY the same crank clearances. They will have exactly the same machining amount of piston to cylinder wall clearances as well as ring gap clearances and so on. There should only have just one specific number to a given areas of tolerances!
http://a7.sphotos.ak.fbcdn.net/hphotos-ak-ash3/s720x720/535302_357366894299245_323914650977803_925401_778751242_n.jpg
1st is reciprocating weight matching. This is done by weighing all Wiseco pistons and pins on a precision scale. Our balancing works still very helpful that each piston & pin now all are equal to 499g. exactly.
http://a5.sphotos.ak.fbcdn.net/hphotos-ak-ash3/s720x720/558595_357366974299237_323914650977803_925402_1634145697_n.jpg
Then the rotating weight are counter-check on our in house balancing fulcrum which determines how heavy all con-rod are at either end. If one rod is a little heavier on where the bearing goes than another, and there is a little weight different have found and removed from the heavier one to balance them out.
