Good day guyz,
actually, this is a simple DIY that anybody can figure out & do it by themselves..
i post this thread out of my 'bored'ness .. hehe
so, plz bare with me
p/s : if u have any question/suggestion, do post it here
Things u need :
1. The Grounding Cable Kit (mine is HKS)
2. Spannar
3. Allen Key
1st Step
Disconnect your battery
I don't think this is necessary but BETTER BE SAFE THAN SORRY
2nd Step
Lay down the cables on top of ur engine so u can get a perfect place to put the round connector thingy
Please make sure your cable can reach all these things :
1. Negative terminal at ur battery
2. Alternator
3. Firewall
4. Distributor
5. Coil
6. Injector
3rd Step
Mount your round connector thingy (i really need to know what's the name
4th Step
Open screw, put the cable in place & screw back at all the item listed above (it doesn't get any simpler than this :proud:)
And you're done
Don't forget to connect your battery back & test start your car
Happy 'DIY'ing
Gudluck
Things u need :
2. Spannar
3. Allen Key
1st Step
2nd Step
2. Alternator
3. Firewall
4. Distributor
5. Coil
6. Injector
3rd Step
)4th Step
And you're done
Happy 'DIY'ing
Gudluck
. But whenever I turn on my AC during night drive, my head lamp will still dim a little and then back to normal. Same goes to my friends's car stock car. So I started to ponder..our cars are new..but the voltage stability is not as good as my friend's iswara with GD and even subwoofer+amp. The head lamp lights do not dim when he switch on his AC!
