ok. i've use d GC for a while & notice these things :
- lights r brighter inside out
- doesn't have electric static.. this can start a fire at petrol station
- performance no difference..
tq![]()
Only GC, not VS??
tq![]()
yup.. GC only just like my 1st post![]()
Try VS, I got better sound quality from my ICE. Of course VS for sound also have, but the one I fitted is for the battery one....
the HKS grounding at rm138 seems very expensive bro.....
inside the VS is just caps to retain/store power, order high quality caps and double the number of Pivot ones so much more beneficial.
VR2Turbo taiko : The purpose of the VS is to tap into the frequency of the current, not become a power bank. They say if they can smoothen out the frequencies it'll result in your electronics working better therefore better car performance. Those power banks do nothing but draw power.
I have a DIY VS that seems to change the characteristics of my Myvi and even my Wira. Took it out to compare and true enough there were obvious differences. However the VS made the car quite rough.
Anyone care to try? The only thing I haven't done is dyno it. Couldn't be bothered to spend RM100 on a humble DIY attempt anyway
A VS is just the same as a Voltage Regulator. The capacitor is to regulate the voltage drop or voltage rise from the battery, thus providing a stable voltage to the electronics. It charges and discharges when there's a voltage rise or drop respectively, resulting in electronics running more efficiently. That's it.
You mentioned you took the DIY VS compare. May I know what comparison you made?
Correct me if I were wrong, coz I cant remember much of it already.A VS is just the same as a Voltage Regulator. The capacitor is to regulate the voltage drop or voltage rise from the battery, thus providing a stable voltage to the electronics. It charges and discharges when there's a voltage rise or drop respectively, resulting in electronics running more efficiently. That's it.
IMHO, VS doesnt give any significant increases in horsepower or torque. Unless your car battery or electronics are really messed up, a VS only let the electronics run smoothly, thus sometimes we feel a smoother ride (cars nowadays are controlled electronically, no?).
One simple measurement to know whether a VS works or not is measure its output voltage and ampere, before engine start, running engine w/o AC,lightings,ICE, etc. And the engine running with AC lights ICE etc. I think the pattern would be with VS, the voltage is more stable and the voltage recovers faster than without VS when a device is switched on.![]()
The comparison I did was with and without VS.
VS is voodoo technology. No one can explain it properly at the same time sometimes it works.
The logic behind the VS that was DIYed (mine) was that the cap targeted certain frequencies. Currents run at certain frequencies and fluctuations cause the electronics to flutter, a combination of a few different caps to hit these frequencies levels out the fluctuations therefore allowing the electronics to run at optimum capacity.
Or so the theory goes.
I dunno how to explain my DIY VS.. if someone wants to try I'm more than willing to loan it to you for experimenting.
that would really be great. I regretted why I dint study well in electronics and power circuits last time.
giving assignments to students hahaMaybe you should give it to your any friend/family/cousins/engineering geek for them to study for their college or uni assignmentsthat would really be great. I regretted why I dint study well in electronics and power circuits last time.
I personally do not think that it is the frequency that is affecting the devices. Unless you are talking about AC, then we'll have frequencies, not to mention single phase or 3 phase voltage. Well, I would say it is the current that your DIY vs plays with. V=IR and the resistance is fixed in this case. If we can regulate the Ampere, I, then we can have a regulated voltage from the batt to the devices. The amp releases coulombs per sec (electric charge) which is also the "energy" (volt is joule per coulomb) to the devices. When the devices get constant energy, it runs better. If it receive more than it can sustain, it will blow. Thus increasing the voltage or amp to a devices does not work. It will only destroy it. Unless we can be precise enough to give it just the max amount.
I'm really interested in knowing the working principle behind your DIY VS. if you have the diagram and hand it over to an electronic engineer, I bet we would know the answer pretty well. Then you can become a professorgiving assignments to students haha
I'm not a electrical engineer either. This DIY VS was done by a fella who is one. If I can get a diagram from him I'll post it up here. He's the same dude who frankensteined old spoilt Defi meters to his Myvi meter panel, so now his EL Meter Panel has a startup sequence and changes colour when it hits the rev limiter set by an external knob which he controls. It's pretty awesome!
My old friend used to make his own brand VS back in the day and sell it here in ZTH. I forgot what that brand was called but he's pretty knowledgable on all things electronics. Let me see if I can drag him into this conversation
bad for us. :rolleyes:
not like those we see inside a Raizin. Not cheap summore lehGood good haha...drag him into this discussion, then we'll find answers lurking behind him. Since he's selling his idea, I dont think that he's willing to disclose the diagram. It is best to keep it, for himbad for us. :rolleyes:
I'd seen some dude selling DIY VS in LYN. Some even show the inside of it...my reaction upon seeing that: lol...inside full of jalan pasar capacitornot like those we see inside a Raizin. Not cheap summore leh
! who can help me!!!!!!!!!!!!!!!!!!!!!!!!where the workshop can help me repair!!!!!!!!!!!!!!!!!!!!!!
