Neuro,its in 500ml aerosol spray can. Said its with improved formula.
thinking to use it on cooler parts, intake manifold and turbo intake side, and engine block.
bugger that foreman told me its Xpensive and troublesome to convert back to OEM setup, make me die die no choice to go cikai adjustable.
Currency Wars, for little more performance and if you have extra money, may look into extractor. Top it with port and polish for engine head.
Done correctly, you will have a reliable, optimized and slightly powerful car. even before i switch to V6, i usually service alot parts in a go. save on time and labour charge.
Danzzz, need advise on driveshaft. start to feel more klicking noise....![]()
just standby ur money, we will racun what to put la..Wah by the end of the year my stock car totally change la like this.Haha,thanks for the info,a lot of new things i learn from this forum ;)
how man litres u have to top up?Mr Neuro i keep in track with my engine oil level.Seems like my engine oil keep kurang.I have to top up once every 2 weeks.The question is should i go for full overhaul or just top overhaul?
The condition of the car in terms of FC and performance is not that bad at all comparing to other perdana in the same year since my dad keep a good care of it. I check with my dad,and for the exhaust system he did the service the exhaust system already(they change the CAT and got some bocor but it's fine now)
I think it's time for the car to get overhaul. May i know the differences between top overhaul and major overhaul in terms of the parts and cost?and which overhaul i should i go for with the current mileage and condition of the car?
CurrWars, im not pro but i got some general stuff for sharing. others sifu, if i give wrong info please correct yah.
If just normal problem assosciated with old age and high miliage i guess top overhaul will be good enough. More on replacing the gasket and seals and rings. as mentioned im not pro enough in engine stuffs, and also not sure on the actual condition of your engine. Might have hidden sickness that cannot be seen.
definately but unable to confirm exact cost due to opening more engine parts involve higher labour charge, and also some parts might need not be replaced. Critical parts i.e radiator flushing, water pump, plugs, belts must be included. As mentioned before, sakit pun 1 time only.
You may want to take the opportunity to perform port and polish on cylinder head, regrind valves.
Slightly bore throttle body and intake manifold, change extractor. Voila. Good to go for few more years with TLC.
do u see white smoke coming out of the exhaust? if yes, during idle or during driving?
if u say the FC and performance are still good, then u can just leave the car as it is.
but if u insist on doing something, then top overhaul is enough.
top overhaul cleaning parts in the head.
major overhaul cleans all the engine.
1st, use water level ruler/tool to measure if the engine is mounted steadily/tegak/not senget.bros, how to know if during transplant the mounting not done nicely? means not balance?
Hi all..perdana v6 user here.
perdana v6 year 2000
mileage 219615 mileage.
auto tranny
stock inside and out.
overhauled once during 120xxx mileage. 205xxx did a top overhauled due to white smoke which cause by the oil seal which wear out after some time. only once change gb during 10xxxx mileage. now recently second time change gb after stuck at free gear at D. after read in numerous forum, feel like i overpaid for the service:
gearbox(eterna auto) + used atf cooler( complete set) + labour + oil seal around 2.8k.
due to yellowish headlight i poison myself to get led headlamp and this:
total damage: RM900 (siap pasang)
and will change my lower arm(front) recon about roughly RM22x (1 piece S and straight)
so what do you guys think..? perhaps i could spend on something better than the lamp set.
led headlamp for RM900???? !!!
look at this...
http://www.mudah.my/Perdana+led+light+bar+tail+lamp+SM0KE+BLACK-19592651.htm
http://www.mudah.my/Perdana+led+light+bar+tail+lamp-15657348.htm
you should go for stiffring and others mah..
Rm900 inclusive of installation set of front led head lamp, and set of rear led tail lamp..
