sanekit
From south? you turn off at Sepang track to PD using federal road?![]()
Nope. My kampung is nearby seremban 2. I cut through sepang f1 and LBJ. now the kampung road people use to cut through mambau and seremban.
Last time, I used that route many times to see the rallies held from Bukit Pelandok to Lukut and PD then follow them back stopping at Sg. Pelek for oyster egg....hhahahha
Isn't that dangerous having the engine shut down at high speed? I thought it's just gonna drag your car at the speed limit and the car can't go more than the limit set?:hmmmm:
Nah, not dangerous. Just that you felt that the engine just hold itself from going further. Kind of potong stim but oh well, JDM vehicles are like that back in the days
Meaning mine got it laa? Coz the car can't go beyond 180kmh. Just stayed at that speed like cruising.. :hmmmm:
Wah! you cruise at 170 plus is hell of a fast brother........![]()
can't wait for top overhaul and pnp. I hope no more sluggish/lagJust get a pivot speed meter V, voila.....
Just to double confirm, your engine head cover proton or Mitsubishi? If proton, then no speed cut
No laa.. I just wanna test the max speed of the car on power mode. Can only go 180 max at 5k+ rpm.can't wait for top overhaul and pnp. I hope no more sluggish/lag
Before you mod to go faster, remember to mod to make it stop faster too and also the suspension to keep it in check.....lol![]()
2nd April DIY TT for the brakes! hehe. for suspension, so far the coilovers are doing a great job. love the handling and it have more comfort than previous sports proride mix with performax springs combo. and the bigger size re003 provides the grip i needed.![]()
Mitsubishi, australian half cut, 240kmh speedometer.
Sent from my iPad using Tapatalk
any idea how thick is c99 wira front and rear arb? will it be too stiff in a satria?
It's 1995 wira 1.8, I plan to take the front and rear arb of the wira to put in my 1.5 satria body..my concern is would it be too stiff causing excessive under/oversteer anyway I will measure it when it's taken out
Sent from my SM-G7102 using Tapatalk
Yeap it's the c99 dohc, so it should be 23 mm front and 13mm rear is it?Is your C99 engine SOHC/DOHC, I assume if its the DOHC it should be the same as the Wira/Satria/EVO 1/Putra's suspension setup. Only the SGTi's front suspension is the same as the EVO 2 and 3.
