You don't mind driving old car then is ok. Some just start work want to show off a little....
You don't mind driving old car then is ok. Some just start work want to show off a little....![]()
If rain cannot wet, is OK lahhh....
Unless got deep pocket. Personal preference..
Actually Saga / Iswara changing 4G9 series no issue in JPJ just need to take care of one mounting properly (Like those Conti cars using Japanese engine style).
Indeed that battery need to move to the back thus only manual applied coz 4G9 series Auto GB is too big where it will hit the firewall..
I saw a lot Iswara running on 4G93 even 4G93T also saw once..
Actually the best still 4G61 or 67.. Even iswara load VR4 also no use d.. like sitting inside speedboat, very hard to control:stupid::stupid:
keep your stock iswara. Not much on road d. I hardly see one also. Maintain 4g13.
No much carb engine on the road too.
i feel sayang lah if replace.
ipoh also less wira missing is it ?![]()
lol...
so true.....
Not much? In Ipoh, they are still everywhere.
If want to keep carb, need go and find twin carb like weber carb. Since already high FC, might as well go all out with twin carb.![]()
1.3 no need twin carb, you might drown that engine.....lol
Down draft twin choke already good enough.....![]()
Fuh! side draft some more......
gg the webbers probably cost as much as the engine dah.....
You should show pic of your old Prelude carb too.
I remember I saw before twin weber for sale at mudah, RM2k. But is the gain really worth the price.![]()
Mine was down draft on an Accord. Prelude was mechanic client's car, not mine. That one from weber 40, not enough change weber 45.....lol
It has been a while since you posted here.
So, these mountings need to be custom made or what? Or is extensive welding needed on engine bay to accommodate these mounting?
4G61 or 67 is too old. Worried later hard to get parts. Thinking of 4G91 is because want something with decent power, average maintenance and FC. The current 4G13 had terrible FC, giving bad power and if send for overhaul, probably like RM2k needed and that is just to restore back a 4G13 carb...
Actually 67 still can get spareparts coz share the same parts as evo and 1st batch of perdana 4g63 but want to get the halfcut is like trying your luck digging gold..
Sorry, I got it wrong mixed up with Prelude. Weber 40 and 45 is the type of weber?
Busy with work.. do keep log into ZTH but no time to post
Need to drill car body to relocate the mounting point if i not mistaken coz forgotten already.. long time back d.. old man already
Yeah 4G67 is also a good option, very solid engine just like the 4G93 but maybe a bit heavier weight and fuel consumption not as good but a bit more torque. As for parts, it's exactly the same parts as the older 4G63 in Galant/Eterna except the piston size and rings, and the block (4g63 block has bigger bore and a bit different water jacket if I remember correctly).
Yup, 40mm vs 45mm....![]()
Here is the tweeter..pioneer TS-T35
it's an old model actually..very2 ol skool...
